Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
When I turn on the broil function in the top oven, the bake igniter glows. I checked the voltage in the wires to the broil igniter and there is 0 volts. Is this a bad component on the ECB or can the ECB be reprogrammed or reset?
  • 24 Answers
This is probably a problem with the wiring outside of the control. To confirm this, check for continuity on the bake and broil relays upon activation of the broil function. If the the broil relay activates and the bake relay does not then your problem lies outside off the control board. I am familiar with troubleshooting Maytag appliances as I work for a company that repairs appliance timers.
Posted on Mar 21, 2011
  • nosoup4u Mar 21, 2011
    Sorry. I didn't mention that when I try to fire up the broiler, the bake igniter glows but NOT the broil igniter. I checked the voltage in the leads to the igniters and found 120 volts in the bake igniter and 0 volts in the broil igniter. When I fire up "BAKE", everything works properly....only the bake igniter glows. Something on the ECB is bad. Both igniters check out.
  • shirarott Mar 22, 2011
    You can check for continuity between the output terminals of the broil relay. If the broil function is supposed to be on and there is no continuity, you should get the board replaced or repaired. The company I work for can repair it for you.
The bottom oven is not functioning properly. When turned to fan oven the fan works intermittently and the element intermittently glows red hot
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
May 04, 2015 | De Dietrich Ovens
I have a Samsung electric range FTQ352IWUX, and neither oven functions (bake nor broil) produce any heat.
THINGS TO CHECK:
the broil element
The bake element
Apr 18, 2015 | Samsung Ovens
My samsung flat top electric oven or broiler want work and it's reading error code E-08
E08 is a oven heating error which basically means there is either a problem with the heater or the oven sensor. In this case i would check the oven sensor with an ohms meter. should read around 1080 ohms at room temp. Also try unplugging the unit for 30 seconds.
Apr 14, 2015 | Samsung Ovens
Why doesn't the oven work?
THINGS TO CHECK:
the broil element
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 11, 2015 | Ovens
No elements working on kenmore range
THINGS TO CHECK:
the broil element
The bake element
Apr 17, 2014 | Frigidaire Ovens
Oven not getting hot
THINGS TO CHECK:
the broil element
The bake element
Apr 06, 2014 | Frigidaire Ovens
Oven element
The bake element
THINGS TO CHECK:
the broil element
Feb 15, 2014 | Frigidaire Ovens
Oven won't heat up, display flashes bake
THINGS TO CHECK:
the broil element
The bake element
Feb 12, 2014 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire elements oven will not ignite
the broil element
The bake element
Feb 05, 2014 | Frigidaire Ovens
Kenmore Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
PS go to searspartsdirect.com, type in your model number for the exact replacement part number.
Oct 27, 2008 | Stoves 500SIDL Gas Kitchen Range
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
1,288 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
