Question about KitchenAid KEMC378 Electric Double Oven
Kitchenaid microwave light & DOOR error code
Model is KEMC378SS01, about 4 years old. Simultaneousy, the microwave oven light stopped working and display started showing DOOR error code when door is closed and I press start. If you have come across this I would be very grateful for your diagnosis. Would like to get a copy of the repair manual if you have a copy. I plan to repiar it myself, even though it means taking the unit out of the cabinet. Thanks!!
  • 1 more comment
  • Anonymous Sep 26, 2008
    same error
  • nevin796 Dec 11, 2008
    I have exactly the same problem but on Kitchen Aid Model KBMC147HSS03 (about 3 years old). No light and error code DOOR comes on when pressing start.
  • Anonymous Feb 24, 2009
    I try to enter cook time and when I hit start I get a "door" error. 4yr old Whirlpool.
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
  • 1314 Answers
SOURCE: Kitchenaid builtin microwave oven # Kemc307KSS
ok the meat probe error is the meat probe is wired backwards yor microwave is a blown fuse in line with the primary interlock switch send me an email at can help the primary interlock switch is a fancy way of saying one of the three micro switches in the door that the hooks on the door trip when its closed
Posted on Jan 25, 2008
  • 1913 Answers
find your manual from here.
Posted on Oct 11, 2008
SOURCE: kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Posted on Nov 29, 2008
SOURCE: KEMS377 Lower electric Convection Oven - no probe, won't work!
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Posted on Jan 07, 2009
I have a kitchenaid KEMc308 Superba Electric oven and micowave combo. Just had the light &door spring replace. Now, it gives code F2 E0 for 60 second and then give code F2 E1. I checked the key...
If you're searching for an obsolete keypad for a Kitchenaid Oven/Microwave unit, has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order.
Feb 02, 2015 | KitchenAid Ovens
Microwave doesn't turn on, code "DOOR"
See if the door is crooked, low, or something is blocking it.
Dec 01, 2013 | KitchenAid KEMC378 Electric Double Oven
I have a kitchenaid convection oven with microwave F6 EO code
Your tring to fix an appliance that's 10 yrs. Old ! Replace is your answer
May 14, 2012 | GE JKP85 Electric Double Oven
This KitchenAid combination wall oven and microwave unit was purchased in 2002. Except for having to replace a fuse in 2004, it worked fine until the microwave started acting up recently. In September...
Good Question. I work on all brands of appliances, and I swear by KitchenAid-Whirlpool appliances. That being said, I do not recommend oven-microwave combinations, because the ovens will last 30 to 40 years, but the microwaves start having major repairs from 6-10 years on. I would bite the bullet and put in a separate Panasonic microwave (with an inverter) and a seperate KitchenAid Oven. You also need to install a 2000 Joule or higher surge protector, for your microwave oven. Panasonic microwave ovens are better than the KitcheAid ovens at this time.
I would suspect that the touch panel-control board failure may have been caused by the repairman, just because the timing is a little too close to the mag repair. No way to tell you for sure, and I myself have had control board failures the same day that we changed a light bulb, so anything is possible. Usually a factory defect is going to show up before 8 years. In the last 4 years in the greater Seattle area, 70 - 80% of our business is from power surges hitting the electonics in the different appliances, so this could also have been what has caused your repairs. On a 240 volt Oven, the only way to protect it from power surges is to have a whole-house surge protector installed on your house electrical panel. You still need to have individual surge protectors, above 2000 joules, for your appliances that are 120 volts. Good Luck, Appliance Specialists
Dec 09, 2010 | KitchenAid Architect® KEMS378S Electric...
Model KEMS308sss microwave not heating - light comes on, turntable works but no heating. Unit is 4 months old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
Nov 13, 2010 | KitchenAid Architect II KEMS308SSS...
Multiple replacement of Microwave door springs
KitchenAid Architect Series KEBC107KSS Electric Single Oven problem error F1E7
Sep 15, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
Displaying DOOR
there is two fuses a 15 amp and a 20 amp fuse on the left hand side of the microwave one or both have blown
Jul 08, 2008 | KitchenAid Architect Series KEMC308KSS...
send me am e mail at with the model number
May 31, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid KEMC378 Electric Double Oven Logo
284 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
