Question about Vacuums
How to install bobbin case for singer sewing machine 5932
  • 17 Answers
SOURCE: I have a singer 600E
Open the slide plate, and remove the needle plate.The needle plate should be raised by a lever on the right hand side of the bed.Move it to the left, then raise the needle or take it out.It is also easier if you remove the sewing foot.Once you have the slide plate moved towards you you will see a black piece of metal in the front right corner of the bobbin area.Lift it up and slide it to the right.Position the bobbincase with the metal flap that locks the bobbin in towards you so when you lift it up it is on the end closest to you.Make sure the bobbin case is in the groove of the hook(the round thing that spins when you turn the handwheel)once you have the bobbin case in position you bring the black metal pieceover to the left and it will drop down to secure the bobbincase.Turn the hand wheel towards you the bobbincase should stay in place and the hook should turn around it.If it turns smoothly replace the needle plate,close the slide plate,screw the foot back on and replace the needle.You are done. www.sewvac.com
Posted on Feb 01, 2011
Testimonial: "Thankyou so much!! I got it back in, did exactly what you said and it worked..awesome!!!"
SOURCE: my singer 4166 sewing machine won't pick up the bo...
I had the same problem straight out of the box. I decided to buy a new machine and came across the 4166. It had more than enough functions and seemed to run smoothly. I too have problems with the bobbin not threading so I took it back into the store thinking I was doing something wrong. The saleswoman had the same problem. I was going to exchange it for another but before leaving I wanted to check to see if it worked. Again, same problem so I left without a machine. I spoke to the owner only to be told that 30% Singer machines are lemons and have to be returned for servicing because they don't work from the start. This is a waste of money and time.
The only suggestion I can offer is to either forget about the machine or take it into be serviced.
Posted on Jun 26, 2010
HansPP
  • 2510 Answers
SOURCE: Thread and bobbin both threaded
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Posted on Mar 16, 2011
wentlanv
  • 710 Answers
SOURCE: i have lost my sewing
Hi, little ducke,
Can't do much sewing without a bobbin case!
I've had a difficult time finding information on your particular model. The best website I could find has pictures of the few different styles of bobbin case in Janome machines. I think if you look at the pics, you'ld be able to pick out the one for you.  Here's the website: http://sewingstyle.com/Janome-Sewing-Bobbin-Cases.html
I hope this helps. If it does, please place a vote or comment for me. Thanks,
Handie Andie
Posted on Mar 30, 2011
HansPP
  • 2510 Answers
SOURCE: How to install leather belt
The belt is a round leather belt and is joined by a wire staple. It passes over the pulley on the hand wheel, down through the slot in the table and a slotted plate goes into the table slot with the belt in the plate slot. The belt is than placed against the big pulley, turn the pulley and a lip on the pulley will pick up the belt and feed it into the groove of the pulley - that's it! (If the belt is too long, cut it to the correct length, pierce a new hole in it and feed the staple into the hole).
Posted on Apr 01, 2011
What can you do to stop squeaking when I'm winding bobbin
Spray wherever the squeak is coming from with a dry silicone lubricant called 'Jigaloo' or WD40 Dry Silicone Lubricant. It is also great for sliding windows.
WD 40 300014 Specialist Water Resistant Silicone Lubricant Spray 11 oz...
Jan 13, 2016 | SewShop.com Singer Model CE200 Quantum...
How to oil the singer 776 swing machine
Singer sewing machine controls - YouTube
? 3:37
https://www.youtube.com/watch?v=yO3OlJXSoMQ
Jun 26, 2012 - Uploaded by cindylouwho0619
1:54. How To Clean and Oil A Sewing Machine - Duration: 12:07. by Niler Taylor 245,750 views. 12:07. How ...
Winding a Singer Sewing Machine Bobbin - YouT
Dec 09, 2015 | SewShop.com Singer Model 776 Instruction...
My needle hits / bottoms out on the bobbin holder and hook assembly. Do do I need to fix timing
there are several things that may cause this situation.
the needle may not be seated all the way up where it is supposed to be.
here is a site that may give you more insight.
How can fix the needle hitting the bobbin case on my sewing machine
Mar 05, 2015 | Singer 8763 Curvy Computerized Sewing...
My machine flashes C4 when i want to sew
Clean the bobbin case area thoroughly, and probably the feed dogs, too. Start all seams by holding the top and bobbin thread ends together behind the presser foot for the first few stitches. If you have lost your manual, pick up a new one, free, at http://www.singerco.com
Mar 21, 2014 | Singer 7256 Fashion Mate Sewing Machine
I received singer sewing machine 2623 machine and I do not have the manual. How can I get it and how do I fill the bobbin
Singer has manuals for most of their sewing machines available at their site. For the 2623, the manual is only available as a bound copy for $15. Go to http://www.singerco.com/accessories/instruction-manuals and enter the model number then click Search.
I believe on this model, you fill the bobbin with it on the metal pin on the top right of the machine. With a metal presser foot in place, bring the thread up and around the guide that pin. Wrap the thread a few times around the bobbin. Set the lever to the bobbin winding position and begin winding. Stop and trim the excess thread from your initial wraps after it is fully caught. Then complete winding the bobbin.
(On other Singer machines, you fill the bobbin in place with the bobbin cover moved halfway open.)
I hope this helps.
Jul 08, 2011 | Singer Vacuums
I am trying to tread the bobbin of the sewing maching (Singer Merritt 4530) but the bobbin is not turing. The plate under the bobbin is turning but the bobbin its self is not
Look up a singer sewing machine store in your area and you can phone them and they will tell you what to do, or you may get them to fix it quite reasonably, or post your ad for free on www.kijiji.ca and someone can help fix it for you that knows how to fix sewing machines.
Apr 25, 2011 | Vacuums
It dose not sew, and when it dose the bobbin tangles up and lets out too much thread
The bobbin goes into the holder in what would appear to be the wrong direction ie, the thread doubles back. If this is correct, the bobbin tension might be too low, there is a screw on the bobbin holder to set the tension.
Jan 24, 2011 | Singer Vacuums
Vacuums Logo
242 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
