How can i configure the button layout of GGE909 for ps3
My nyko raven wont sync with my ps3
reset controller then press raven button while light is flashing
Jan 30, 2011 | Nyko Raven Motion Sensing Wireless...
Why wont my nyko raven controller connect with my ps3
reset controller pin hole on back then press raven button while light is blinking
Dec 25, 2010 | Nyko Raven Motion Sensing Wireless...
I need software & manual for GGE909 rumble pad
Hi.
GGE909 rumble pad software (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 25, 2010 | Game Elements GGE900 (51691)
When i press certain button it reacts as if i pressd another button. this happened on both my controllers
try to connect the controller with a USB cable and press the RS button if the buttons are all weird it may be the button layout
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
Dlink accesspoint doestnot connect with playstation3
The Dlink wireless modem is configured correctly and the computer/laptop can access the Internet wirelessly.
The PS3 needs to be configured with the Dlink modem's wireless settings so it can communicate with the wireless modem.
To configure the PS3 please follow these steps :-
1. Power up the PS3 and login then Select Network Settings and
press X
2. Select Easy then press > button
3. Select Wireless then press > button
4. Select Scan then press > button
5. Select the wireless modem you want to use, then press X button
6. Confirm the SSID for the wireless modem then press > button
7. Select the security settings (ie WAP, WPA - this is the in the wireless modem settings) then press > button
If there is no encryption I suggest you enable the encryption on the wireless modem, use passphrase to generate the encryption key.
Write down this encryption key, you will need this key for your computers and PS3.
8. Enter the WEP or WPA encryption key (from the wireless modem) then press > button
9. Check the settings then press X button
Dec 23, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
I want to connect my telstra wireless modem to my PS3
I assume the Telstra wireless modem is configured correctly and the computer/laptop can access the Internet wirelessly.
The PS3 needs to be configured with the Telstra modem's wireless settings so it can communicate with the wireless modem.
press X
Dec 22, 2009 | Sony Computers & Internet
The USB part has broken off my GGE909 Game Elements Recoil PC controller. I want to know if I can use a different USB cord to attach to make the GGE909 usable again. Is it possible to fix?
The GGE909 uses a flat ribbon cable with eight wires, and has a spring loaded spool to store the cable.
Using a standard cable might work, but the new cable probably won't retract in the spool.
Sep 05, 2009 | Video Game Consoles & Games
I need a driver for my game elements gge909 gamepad for vista os
GGE909 can work under Vista and 7 without driver. hoever the "ESC" and "ENTER" key doesn't work. I wondered that the manufacture havn't write driver for Vista and 7.
Nov 16, 2008 | Video Game Consoles & Games
Keyboard changing key configuration
the key combination you mention is Left Alt + Left Shift.
It changes the keyboard layout to the next one in the listed of available keyboard layouts.
To configure the layouts, go to Control Panel -> Regional and language settings -> Languages tab -> Details
Under Installed services, the keyboard layouts that are currently installed are listed.
If you don't need to change (is needed if you want to type norwegian for example, since it has some special characters), you can simply remove all unnecessary layouts.
May 23, 2008 | Logitech Cordless Desktop S 510...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
