Question about Memorex MLT3221 32 in. LCD TV
The wordd memrox displays quickly and then turn off
  • Memorex Master
  • 5,568 Answers
Since you do have briefly, this indicates that the more complex section of your set is working.
The assembly that can cause this is the power supply and this is a common failure in all too many of more recently built TVs.
The supply is normally built on a separate board since these are often out-sourced by set manufacturers.
Unplug your set overnight to allow potentially hazardous voltages to discharge, remove the back panel of the set so you can see the guts.
Look for a smaller board with larger parts on it; some cylindrical (capacitors), others block-like and relatively large (chokes and transformers).
You should also see a relationship between the board and the incoming AC.
It will likely be only plugged into various others with dissimilar plugs so it should be easy to remove and replace.
Check the board for a label or if not present, a stamped-on number.
Call the manufacturer's service center with your TV model number and the number found on that board and inquire about repair/replacement costs; if both are offered, they won't be that much different.
If you must buy a new board, don't dispose of the failed one as there are smaller companies that can repair it for less than the mfr. and then keep it as a spare as this problem will likely arise again.
Posted on Mar 20, 2011
  • 11,361 Answers
Please read my guides to get some understanding about LCD TV.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 21, 2011
On Screen Volume Adjusment
go to control panel and pick sound icon, tick the box that says display in taskbar.
Jul 09, 2014 | Acer Aspire 5500 5570-2609 Laptop
Display is out
Push the swing button 2 times quickly. This will turn the display back on.
Jan 15, 2014 | Soleus Air KFHHP-12 12000 BTU Mini Split...
How to set temperature on GE Profile PSS26NGPA WW?
Press and hold temp up button then press quick freeze button at the same time, your temp settings will be displayed on display for fridge and freezer, fridge temp is + and freezer -, cycle by pressing quick freeze, set temps by up and down temp buttons, once done, push vacation button. your temps are now set, turn the unit off for 2 mins the turn on. reaction is now set and normal. regards Russ
Jul 03, 2012 | GE Refrigerators
Instructions were for a different fully analog model. The major problem aside from the digital settings, is the mechanical setting of the hands. Even after pulling crown out to position 3, the hands won't...
Tag Multigraph: With the crown pushed in you turn the winder quickly a couple of times and the digital displays appear. Scroll through to the function you want then pull the crown out and turn it to change time/settings. The time can be changed either by pulling the crown out on the T setting (digital) or when no digital display is shown on the dial. If you turn the winder slowly the time/settings change very slowly, which is barely visible. If you flick the winder round very quickly the settings leap forward faster.
Aug 05, 2009 | Tag Heuer 2000 Classic Multigraph...
Review the pictures
Using the Quick View Button Press the QUICK VIEW button. The last picture taken is displayed. Use the arrow pad to display other pictures. Press the QUICK VIEW button again when you are ready to take another picture. Using the Mode Dial Turn the mode dial to the playback option (the green arrow). Use the arrow pad to navigate to your picture of choice.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
Review the pictures
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Review the pictures
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Memorex MLT3221 32 in. LCD TV Logo
586 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
