Acer Aspire 5610-4648 Notebook Logo
Posted on Aug 02, 2008
No sound on video
Any advice would help thanks
Anonymous
Level 1:
  • Contributor 9 Answers
  • Posted on Aug 03, 2008
Anonymous
Contributor
Level 1:
Answers
9
Questions
0
Helped
47515
Points
81
Please double click on the speaker icon present on the taskbar on the right hand side. you will get a master volume window. Now check if all the checkboxes are not ticked. If any one of the checkeboxes are ticked, please untick all the checkboxes and try again by playing a video or audio. Now your problem will be solved.
Thank you.
1helpful
AVR142 totally shutdown no lcd display no lights on volume control no sounds only main switch have a light,plz help me thanks a lot
Sounds like either a blown main power fuse or power transformer. If the fuse is blown it probably means a short in the amp somewhere. If it is the transformer, it can be replaced - but may cost more than the unit did.
Sharp aquos lc-32le600E connected to PC video is fine, but no audio, any advice? Thank you in advance
Good job---Thank You for letting us know you got it and thanks for using FIXYA.
**** Sound
This sounds like a hardware problem ... please contact your service provider for advice in repairing or replacing your handset.
Thanks for your interest in FixYa.com
4helpful
8answers
I have no sound in my pc!
change from windows to xp,but sound driver was not loaded/installed so there is no audio sound in
my pc.from where n what driver to install in window xp for free.kindly
advice n thanks.
Cables to connect laptop to tv
Yes you will need a 3.5mm to RCA/composite cable and you should also most likely have an S-video out on your laptop so you will need an s-video cable.
If you need more help give me exact make/model of laptop. Also what connections your tv has.
Thanks,
Lee
I NEED A INSTALLATION DISK FOR MY LEXMARK PRINTER CAN YOU HELP?
Hi TAPPHT
If you go to this support page, enter your particular model, and the drivers and software are all there for your downloading.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
No sound from right speaker when mp3 connected through aux
Hi bustero78
What happens when you rotate the plug or wriggle it about. If it cuts in and out, then you may have a faulty interconnect lead, or a dodgy socket/plug connection to the player. If it works with headphones, I would suggest replacing the lead.
regards
robotek
2answers
RCA F36685 No audio on cable channels
1)Try hard reset = unplug AC cord overnight
2)Further audio circuit work is shop repair by skilled,senior
RCA products technician........................................T.
6answers
Problems with Playback and No Sound..
It seems you are having a tracking problem. When the tracking is out of sync, you will notice digitized drop out then even audio distorts. It is caused possibly by shift in mechanical system or changed value of electronic components in tracking circuit. It is standard repair cost to remedy this kind of problem. Probably cost you around $125-200 in US repair shops.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
