Question about Psyclone Bass Pro Shops: The Strike : Wii for Nintendo Wii
On The Strike, while driving the boat, it will only turn to the right after using the game only a couple times.
    Filmmaker:
    Uploaded 5 video answers.
  • 84 Answers
It sounds like there is something wrong with your controller, there is no reason why the game its self wouldn't let you turn.
Posted on Mar 21, 2011
  • bellana51 Mar 21, 2011
    Problem was fixed by changing the driving controls (under Options) from the reel to the arrows on the remote.
What's the use of the Air Hockey Mallet?
The Air Hockey mallet is used to strike the pucks along the Air Hockey table in the direction you want to strike. You should strike the puck with enough force in order to be able to score a goal at the other end of the table, after a couple of game you'll get the idea.
Jul 25, 2012 | Sport & Outdoor - Others
Need a motor boat in the game
you have many motor botes in GTA 3 and GTA Vice City as well,
you can get them when you go to sea or river like area.
to go there, you can get any car and drive it on water using the cheat "saways" .. with this, you can drive any vehicle (Except Bikes) on water. Go to the boats, find some step/place to change from the car to boat..
once you see it, you will find the way,,
Apr 14, 2010 | Rockstar Games Grand Theft Auto III & Vice...
Washer full of water wont rinse or spin can hear timer running/ model wirlpool imperial series ultimate care 2
First of all, if the model you have this question listed under is correct, this washer does not use a drive belt. It is a direct-drive transmission that uses a motor coupling in place of a drive belt. If the motor coupling were bad, the washer would not agitate at all.
Secondly, the pump on this washer is ALSO used to recirculate the water during the wash cycle. It is not true that it is only used to drain the wash tub. These pumps are driven by the drive motor and only have one moving part - the impeller. If the pump were seized, the drive motor would shear off the drive shaft of the pump.
Check your lid switch.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
If the washer still drains, but will not agitate or spin, the problem is your motor coupling. The following link explains how to access and replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided and only costs about $11 at appliancepartspros.com. These couplers do wear out due to normal wear and tear and need replaced from time to time.
If you have questions, or need additional assistance, please let me know. Please post back with a complete model number (located on a nameplate around the wash tub opening) with your questions, so that I may be able to provide you with better assistance. I hope this is helpful.
NOTE: You do not need to bail or empty the wash tub to complete this repair.
Sep 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
COD 4 connection issues
try finding out what ports COD4 servers use and make sure your router/firewall is not blocking them
May 28, 2009 | Microsoft Xbox 360 Console
Inspiron e 1505 does not turn' on
It could be a couple of things, but it seems most likely that it is the RAM Memory that is causing this.  You might need to add more.  I have seen this before with one of my customers, we upgraded his ram from 1.5 to 2 gbs, and his games/windows no longer crashed
May 08, 2009 | Dell Inspiron E1505 Notebook
Hay I just have one question, In the first lvl of Mercanaries 2
Later in the game you can buy more air strikes, or you can use cheats. To enable cheats, press Back to activate your PDA, then press LB, RB(2), LB, RB, LB(2), RB(3), LB. Then press Back. A message will confirm correct code entry. Then, enter this code at the PDA screen while the PMC on the map is highlighted to activate the cheat.
Right, Left, Down, Up, Right, Left, Down. This will unlock all the airstrikes except the nuke. To unlock the nuke as well, enter Up, Up, Down, Down, Left, Right, Left, Right.
Mar 30, 2009 | EA - Electronic Arts Mercenaries 2: World...
RADEON X1650 AGP 512 MB, COUNTER STRIKE SOURCE ALWAYS LAG
Either turn down the graphics settings in game, make sure you have all the correct drivers installed, or check your internet connection it may be too slow. Hope this helped:)
Mar 24, 2009 | Electronic Arts Counter-Strike: Source for...
Counter-strike 1.6
see if your mouse has left hand properties
control panel set up mouse OR
If you cannot switch your weapon to the right-hand, please go to your advanced video options and change the renderer to either OpenGL or Direct3D. The software renderer does not support right-handed models.
You can select left or right-handed models by typing the following command into the Console:
  • To use your left-hand: cl_righthand 0
  • To use your right-hand: cl_righthand 1
You may wish to create a userconfig.cfg file with the cl_righthand 0 command if you would like to keep the left-handed setting. Please follow these instructions to create a user.cfg file:
  1. Locate the subfolder in your game folder that holds the config.cfg file
    For example, you can find the config.cfg file for Counter-Strike at [Steam installation directory]\steamapps\[your Steam account name]\counter-strike\cstrike\config.cfg
  2. Create a new text file in that directory called userconfig.cfg
  3. Open the file with Notepad and enter cl_righthand 1 (to use the right-handed model) or cl_righthand 0 (to use the left-handed model)
  4. Save the file
  5. Launch the game to test the user.cfg settings
Jan 21, 2009 | Sierra Online, Inc. Half-Life:...
Psyclone Bass Pro Shops: The Strike : Wii for Nintendo Wii Logo
69 people viewed this question
Top Psyclone Video Game Consoles & Games Experts
James Wishart
Are you a Psyclone Video Game Console and Game Expert? Answer questions, earn points and help others
