Question about Garden
Shindaiwa 488 chainsaw repair manual with schematic of fuel system
Do I mix the fuel for my shindiawa 575 chainsaw
Re-fill with fresh fuel of the correct mixture
(Shindaiwa Premium 2-cycle Engine Oil
and gasoline-40 : 1 ratio;
other brands-25 : 1 ratio).
Workshop manual
http://www.golftechs.us/Manuals/shin%20chainsaw_current.pdf
Dec 12, 2016 | Garden
Shindaiwa eb802 hard to start
If it is not the fuel hose thats porous or bad tankairiation it will be also not the spark color red gaskets or ??? , remove the muffler and look at your piston side Look through the outlet port that it will have no grooves because you have lost compression on the piston by or a bad cooling to high rpm's and or bad fuel mix or (L + H) adjustment of the carburetor if there are grooves on the exhaust side
This is an little suggestion made by repair an other brand but it make no difference
Husqvarna husky 240 chainsaw Piston Cylinder Inspection
Mar 13, 2016 | Garden
Fuel mixture ratio
Oil Mix Ratio:
Starting in the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl and Tanaka all started recommending 50:1
  • 1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil or
  • 4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen recommend 40:1
  • 1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil or
  • 4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
Jan 07, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
FUEL MIX
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 05, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I need to know what the fuel to oil ratio is on my Stihl mini boss chainsaw
Oil Mix Ratio:
Your OM can be found here:
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
If you want to verify my recommendation.
Lou
Sep 04, 2010 | Garden
Fuel oil mix for a Poulan 14" saw ?
Oil Mix Ratio:
Sep 02, 2010 | Garden
Oil to gas mix
Oil Mix Ratio:
Lou
Aug 10, 2010 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
Just bought a McCulloch 32cc, Mdoel 3214 from a pawn shop with no manual. Does it require mixing oil with the gas and if so what ratio?
Fuel requires 2-cycle oil be added, bar oil is straight from the container.
Oil Mix Ratio:
Lou
Aug 06, 2010 | McCulloch Garden
, No.455 Rancher, 20" Gas - Powered Chainsaw: What is the oil mixture ratio for the Rancher 455...
50: 1; You can download an OM here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years and is what Husky suggests for your saw..
Lou
May 10, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
304 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
