Question about Watches
How do you set that taking part for daylight savings time on a Reizen Royal talking watch model 9908? I already reset the hands, but the voice is still on standard time?
  • 13433 Answers
SOURCE: Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
Brian032472
  • 150 Answers
SOURCE: Help setting the time
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
Posted on Nov 06, 2008
escapement
  • 2334 Answers
SOURCE: Citizen Eco-Drive Skyhawk JR 3060-59F
Paste this link into your browser and follow instructions:
http://www.citizenwatch.com/CUK/English/settings_int.asp?caliber=C650&interactive=C650
If this is not the correct caliber number, click on technical support tab in the same webpage and find the right one for your watch.
DO NOT FORGET TO RATE, PLEASE.
Posted on Mar 09, 2009
  • 4 Answers
SOURCE: changing analog hands / time function due to daylight saving time
Download the manual from
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Posted on Mar 24, 2009
escapement
  • 2334 Answers
SOURCE: Daylight bloody savings
Follow this link:
Rate me, please.
Posted on Apr 08, 2009
How do you change the battery in a reizen talking watch it is radio controlled white face with black numbers
  • Remove back
  • Find battery. Note mounting arrangement for later.
  • Identify battery type
  • Obtain replacement battery
  • Remove old battery
  • Install new battery with correct polarity
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your watch to a jeweler who, for a reasonable sum, will handle replacement.
Take TTTT
Dec 02, 2016 | Reizen Watches
I have a talking watch. It did not upddatetime for daylight savings time.
unless you have a very expensive watch that has an inbuilt calculator the is programmed to change the time for daylight savings , the change is up to you
simply set the time as if you would do if replacing the battery
Nov 03, 2015 | Watches
How to set time on GPS watch
From your comment I have no idea what watch you have! The more infromation you provide, the likelier it is we will have a solution. However, in general, watches cannot tell if you live in a spot on the globe that uses daylight savings time. You have to enter that information. Go into your settings and see if you can turn on Daylight Savings. The watch should set the time automatically at some point, occasionally takes some time. Only a part of the world uses daylight savings, invented by Ben Franklin to save energy(coal oil) just like today!
Nov 07, 2011 | Citizen Watches
Daylight saving time
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
Apr 13, 2010 | Citizen BL5314 52E WR200 Eco-Drive scyba...
Turn off alarm and how to set alarm
After a bit of searching I found a makers name for you. I trust that this is the make you have (I doubt if there is more than one!)
If you go to "www.accessible-devices.com/reizen.html", this is an instruction sheet for Reizen talking watches.
Jan 20, 2010 | Watches
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Changing analog hands / time function due to daylight saving time
Mar 13, 2009 | Casio DB360G-9A 30 Pages Telememo Watch
I don't know which buttons are which on the Reizen Watch
Get explanation here:
http://www.accessible-devices.com/atomicwatch.html
Do not foget to rate, please.
Mar 11, 2009 | Watches
Watches Logo
54 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
