Question about Winsource Tech Solutions TS-4500 Cross-Cut Shredder
Office has a ts6500 shredder in which I believe the paper sensor (activates actual shred) has failed. Any resource link that you are aware of for parts. True work horse - trying to fins a solution. THX!
  • 18 Answers
SOURCE: My shredder stop shredding. has paper caught in itposted
If your equipment makes abnormal noise when you try to switch on again then gear problem is confirmed else the change over switch should be defective or there may be a open circuit in the change over switch connection I shall advice you to call the service engineer for fixing the problem else take safty pecaution to attempt repairs
Posted on Sep 02, 2007
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Posted on Sep 08, 2007
fellowesrep
  • 102 Answers
SOURCE: fellowes paper shredder
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Posted on Mar 02, 2008
danforddan1
  • 192 Answers
SOURCE: shredder won't shred
They may be a compression switch on the lip where it sets on the bucket. This it to prevent it from running while its off its buckette. If this is not all the way in it wont run. Look for that clean any safty switch or buttons you find.
Slap it with your tax booklet and call me in the morning. Good luck DFD
Posted on Apr 16, 2009
  • 133 Answers
SOURCE: broken plastic teeth
I suggest you just go buy a new shredder, otherwise, if you really want to fix it. That would cost you more then you go buy a new shredder.
Posted on May 23, 2009
Shredder will not work in automatic mode
There might be a tiny scrap of paper blocking the sensor, which will keep the motor running.
Dec 06, 2016 | Shredder Office Equipment & Supplies
Unit will not stop
Dear Hal,
Here is some generic information about shredders that may help you.
Most of the shredders have a micro switch that "senses" if the paper has been introduced to the shredding slot. These micro switches are activated by a little arm/leveler that touches the paper and activates de contact inside the shredder housing. Also, note that some shredders may have an optical sensor that may be "clogged" with paper dust.
If you shredder does not stop, the sensor may be stuck in a on position, or, in case it has optical sensor may be detecting dust or a little piece of paper may be blocking the optical sensor and keeping the motor running.
I hope this gives you some light in further investigating your problem.
RC
Apr 14, 2014 | Office Equipment & Supplies
Royal mc100mx
Dear Michael,
RC
Mar 21, 2014 | Royal 29140X PX100MX Cross-Cut Shredder
Shredder won't shred. can't hear motor in the forward setting only in reverse
Silverfox007:
There is a paper sensor at the throat of the machine that turns the machine on when it is activated by the paper when the paper is inserted. Something has happened to that sensor. Unplug the machine and remove the shredder head from the basket. Use a screwdriver to remove the screws at the bottom of the shredder head and open the shredder head. Look where the paper is fed into the machine and you will see the sensor. It may be unplugged/wire broken/sensor flag broken off... You'll know what to do when you identify the problem.
Sep 06, 2012 | Office Depot ATIVA DX120P Shredder
My shredder won't shred paper. It sounds like something is stuck / locked. I removed any paper shred and still nothing.
IF you've had that shredder for any longer than 4 years its about time to trash it. And some models of shredders actually can't shred anything thicker than normal notebook paper, even after about a year. Make sure you haven't
Apr 25, 2011 | Memorex Office Equipment & Supplies
Cutters do not activate when paper is fed into slot for shredding Office Max model omo1288
make sure sensor switch is free and clear. unplug first before cleaning out. You will see little swith if you look inside where paper is fed in. GL
Dec 22, 2010 | OfficeMax 0M96431 Shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Shrededer motor remains on after shredding is complete
Blow out the sensors with some compressed air.(Computer Duster) they are likely covered in paper dust and the machine believes paper is present.
Please be sure to unplug the machine before attempting any sort of repairs
Hope this is of some help
Ed
Apr 20, 2009 | Fellowes SB-99Ci Shredder
79 people viewed this question
Top Winsource Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Winsource Office Equipment and Supply Expert? Answer questions, earn points and help others
