Compaq Presario Notebook Logo
Posted on Aug 02, 2008
COMPAQ PRESARIO F577CL Wont power on???
My Presario wont power on does nothing. I pullled battery and tryed using a/c adapter but still nothing. I checked the adapter it seems to e god.
Any ideas?????
Thanks
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Aug 09, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
9
Helped
1081
Points
15
Just do one thing go to your nearest compaq service centre and tell them your problem then they will do it right
My compaq presario cq60 wont turn on
Does the laptop boot? Sound? Do you see a "ghost Image" in the monitor in a bright light? If so, Could be backlighting, Inverter, on/off switch that shuts the monitor on/off when you open and close the lid. Can you boot to safe mode with networking? If so, Open the Device Manager, Uninstall the Graphics Adapter, reboot, the software will apply a generic driver, If the Graphics adapter has not failed completely.
1helpful
I turned my compaq notebook on and it turned right off and wont power back up
Try to remove battery and power adapter.
Press power button for 3-4 sec.
Plug in the power adapter.
Power on. After that you can connect the battery as well.
I have a Presario F730US laptop and my battery wont charge?
Try this,
Remove battery and ac ADAPTER from the laptop
Press and Hold the power button for 40 sec(No battery and No Power chord)
Connect the battery back to laptop
turn on your computer,
Login to windows
check the battey backup
Connect the Adapter back and check the the battery life
Compaq presario f577cl wont turn on
Turn it on, then hold the power button for 4 seconds until it forces off. Turn on again.
Otherwise, turn on, remove battery, insert battery, turn on.
Please rate.
The last time I used my Compaq Presario v2000 I had it on battery power. The battery died and now that I am trying to use it I have the power adapter plugged into it and I get nothing when I hit the power...
This problem is either due to your power adapter, wall plug or the back of your lap top where the power adapter goes into. My guess would be the power adapter, they are infamous for going bad. Try wiggling the cord that connects to the power brick (black box) from your lap top.
Presario C500 Wont turn on
sounds like the d/c adapter was either installed backward or the wrong part was installed, also check the connector on the new power cord to the laptop, you may have gotton an incorrect power cord. because what you describe is the internal power system is shorting out. take battery out and check it with a volt meter , if the is no volts/or negative volts on the battery ,it has gotten internaly reversed , and needs replacement.
Laptop wont power up on batter but will on adapter
It sounds like you dc jack is not functioning if you are could with solder and disassemble you can do that yourself . Otherwise you can get it repaired for around 75-100 dollars
Laptop wont start ... ( Presario 700 )
chk your ac adapter bro .. i think its not working
1helpful
Presario M2000
i need intel presario m2000
Cannot get laptop back on
Try removing the battery and using just the power adapter, some laptops wont power on if the battery is bad.
Try hitting F1 as you start it and see if you can get into the bios and reset everything to defaults.
then restart it and see.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
