Question about Kenmore Dryers
Sears Dryer 60932 won't start. It won't heat and the motor won't turn on. It is getting electricity because I can hear it click when I hit the start button and hear some faint clicking sounds for a few seconds. It clicks off when I open the door or pull the plug. Any ideas? I'm comfortable with minor repairs and parts replacements. Dave Rosen
    President:
  • 1,554 Answers
This is a symptom of a blown thermal fuse located on the blower housing. This thermal fuse is wired in series with the motor and power to the motor is cut when it blows then the motor cannot run and no dryer function works. Click on the link below for the instructions on how to troubleshoot this kind of dryer problem.
Troubleshooting Whirlpool and Kenmore Dryers Not Starting
Posted on Mar 21, 2011
My maytag Neptune dryer is not working. It makes a noise when you hit the start button but doesn't start. The timer continues to go until it reaches stop. Have checked belt and it seems to be fine? Any...
I have worked at sears appliance have come across exact or similar problems. You push the button and you hear something like a loud buzzing. My experience has been that the drive motor is locked and needs replacing. Depending on the age of the dryer and the cost of a motor and installation, you might but another dryer.
Mar 03, 2015 | Maytag Neptune MDE4000 Electric Dryer
My dryer will heat but won't turn, I replaced the Dryer motor but it still doesn't turn. The door switch works fine, when I push the start button it clicks like normal and when I open the door I...
Have you looked for a belt on the drum of the dryer? Mine has a motor but it is attached to a wheel that turns large belt that extends around the drum.
Oct 03, 2017 | Roper Dryers
The machine will not start. You hit the power button in comes on, but when you press the start button -- nothing happens. You can hear the clicking while pressing it - but it doesn't start drying.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 23, 2011 | General Electric GE DBVH520EJWW Electric...
I have a Whirlpool gew9868kl3 dryer. The dryer only clicks when you try to start it. I did the diagnostic check on it and I do not come up with any errors. I did however find two things during the check...
one of 3 things can be wrong 1) make sure on an electrically heated element dryer that you have 240 volts,because if not either the timer or motor wont turn and it will not heat without 240 volts,2) if you can hold the start switch in the start position and you can hear the motor running then its a broken belt and there is a switch on the idler pulley tensioner bracket to stop the motor so if the drum wont turn the unit also wont heat to protect against overheating clothes starting a fire. 3) if no sound then either the motor switch is bad or there is a wire off the motor start switch which is very common due to vibration
Apr 12, 2011 | Whirlpool GEW9868K Electric Dryer
Dryer will not start. Electrical source is ok, light is on and your can hear timer running. When you hit start button you can only hear a click and nothing happens.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 01, 2011 | Whirlpool WED5300S Electric Dryer
Stops before clothes are dry
Sounds like a motor going out . You need to replace the motor .
Jun 29, 2010 | Kenmore 65924 Electric Dryer
Kenmore 64112 dryer wont start when I hit the start button
Check house fuses or circuit breaker.
Pull 220V cord from wall outlet and inspect the gold prongs.
If you see any burnt areas on the prongs the outlet is bad.
If the unit makes no noise when you press the start button check the dryer door switch and make sure it clicks when depressed.
Sometimes the door switch arm can break off so when the door closes
the door switch cannot be activated.
If you hear a growl noise when you press the start button 2 things...
1. The motor is bad and needs replacing.
2. An object fell down the lint trap and is preventing the motor from turning.
Also if the dryer vent has been plugged causing the dryer to over heat a saftey fuse may have blown and needs replacement.
Jan 16, 2010 | Kenmore 64112 Electric Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Dryers Logo
150 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
