Question about Kenmore Grilling
Gas grill will not stay lit. - Kenmore Grilling
TheMobilian
  • 8220 Answers
SOURCE: Grill wont stay lit
These new tanks have a safety device installed in them . If you open the valve quickly or tip the jug the damn thang won't work. Take the tank loose, open all the grill valves and close all valves. Reconnect the tank and SLOWLY open the valve a hair. Light the burners. No need to open the valve all the way. if you do the dumb safety will plug the jug.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 08, 2009
  • 10 Answers
SOURCE: gas grill
Probably 1 of 3 things:
Check your LP tank valve at an LP filling station. Make sure both valve and tank are in working order.
Next check for webs or cocoons up around where knob valves go into burners. You may have to remove burners to see into back of valves. Then swab orifice holes with a torch tip cleaner.
Third, a Menards , LP outfitter/station, or grill shop should have a universal replacement rubber gas line and "regulator"(possibly plugged or stuck shut). Sometimes you end up with cheap/bad regulator out of the factory.
Good luck and hope one these helps or does the trick.
Posted on Apr 11, 2009
  • 11 Answers
SOURCE: poor gas flow. Burners will not stay lit. Gas
Try taking a large hammer or set of vice grips and banging pretty heftily on the tubes feeding the burners. These are usually build ups of Carbon. If not, then make sure your connections are good (sort of move them around to see if they are loose), and make sure your propane is not getting too close to empty (you can shake it around and feel/hear the propane).
Posted on Aug 10, 2009
bulldogchief
  • 388 Answers
SOURCE: our grill doesnt seem to be getting enough gas to
How are you turning the grill on and off? It sounds like a vapor-lock. Try this: first unhook the regulator and crack the valve on the tank open...if you hear and smell gas coming out, good, close the valve and re-connect the regulator then open the gas valve then turn the burner on and light it...then shut it off by closing the tank valve first and let the burners go out then turn off your burner valves...try that and let me know what happens.
Posted on Sep 08, 2009
SOURCE: grill doesn't stay lit for the first 20 times, then does
regulator, is faulty, you need to replace it.
Posted on Apr 06, 2010
I'm having problems keeping the grill lit on my BEKO dvg593-mk2 gas cooker. This has been a problem almost since new, i have to depress the gas knob, and keep it pressed for about 5-8 min's after ingn
Here is the owner's manual or try calling customer service at 0870-241-1321 for help. http://www.manualslib.com/manual/15108/Beko-Dvg593.html?page=3#manual
Feb 12, 2015 | Grilling
My gas grill will not stay lit and it is almost brand new
Your regulator may be going bad, try replacing the regulator and hose, easy to do and inexpensive. Of course, check the level of propane in the tank first.
Jul 13, 2010 | Weber Genesis Silver B Grill
Does not stay lit. It heats up, runs for a minute
You are having a common problem with gas grills. Click on my username and scroll down my profile to find my tips and tricks for trouble shooting common gas grill lighting issues. Hope one of them helps.
May 16, 2010 | Viking VGBQ410-3RT Grill
Grill doesn't stay lit for the first 20 times, then does
Apr 06, 2010 | Weber Q Grill
Burner will not stay lit
try to replace the regulator on the grill
Mar 20, 2010 | Ducane 30400042 (LP)
Poor gas flow. Burners will not stay lit. Gas
Aug 10, 2009 | Amana 5939 Grill
Grill wont stay lit
May 08, 2009 | Brinkmann Charmglow 810-7600-S Grill
Grilling Logo
305 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
