Question about Acer H233H bmid Monitor
I purchased an Acer P186H LCD Monitor in June of 2010. It worked until now. I have a white line down the whole left side of the desktop that is about 3 inches wide. How can I get rid of that?
    Sergeant:
    Champion:
  • 223 Answers
It seems a lcd pixel problem.
You should contact Acer customer care and see if they change your monitor with a new one.
Posted on Mar 20, 2011
  • Acer Master
  • 3,606 Answers
Maybe you should try to upgrade the graphic driver in
your pc.
I don`t think the screen has a defect.
It could also be a loose connection.
You can find the graphic drivers name and number in the device manager.
Hope this will help you.
  • racingken01 Mar 26, 2011
    Try updating your monitor drivers also
Vertical gray lines
If you can obtain a desktop monitor used for PCs, plug it into the side port on the laptop. Start up the system and see if it runs OK on the external monitor. If so, the problem is with the LCD display on the laptop.
Feb 27, 2014 | Acer Aspire Computers & Internet
What is the resoltion setting for a acer monitor
The resolution settings are defined by your operating system you are using.
Older than Vista:
Right click on the desktop choose properties
Settings tab at the top
Oon the left side the bar until you reach 1024 X 768 ( most web site are created by this resolution.
Vista or newer:
Right click on the desktop choose personalize.
At the bottom of the page that showes up click on Display Settings
On the left side the bar until you reach 1024 X 768 ( most web site are created by this resolution.
Hope this helps,
Terry
Nov 15, 2012 | Acer V193WEJb 19 inch Widescreen 50000:1...
Large 3 inch white line running down the left side of my desktop. Purchased this monitor in June of 2010. How can I get rid of this. Thanks
your pc.
Mar 20, 2011 | Computers & Internet
Montor has colored lines on left side
Are we talking thin vertical lines that run all the way from the top of the screen to the bottom? If so, this usually indicates a failure of the chip controlling that line of pixels.Unfortunately, there is no easy repair for this and the screen will need to be replaced.
Mar 02, 2011 | Acer FP563 (White) 15" LCD Monitor
I just purchased a new monitor. Where do you hook up speakers on the Acer P186H LCD monitor? I can't find an audio jack on the back of the unit.
I don't think this monitor has a place to hook up speakers. Not all monitors has this, and truth be told, they really **** bad anyways. Just get some semi-decent $50 ones, which will probably be many times better anyways.
Oct 13, 2010 | Acer Monitor
Purchased acer al2216w lcd monitor off ebay. turned it on and it had a vertical red line running from top to bottom near the right hand side.i started to copy a dvd and the screen went black with line...
The screen is bad, verticle lines, red or pink hue etc. is indicative of a bad screen or there maybe a problem with the data cable you are using to attach to the computer. Try another cable first, if the problem persists, the lcd panel is failing.
Jan 18, 2010 | Acer AL2216W LCD Monitor
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
I have a single yellow vertical line running down the left side of my computer monitor, nothing has been dropped, and it doesn't appear when other monitors are plugged into the same computer.
Let me guess, its an LCD? Unfortunately this has happened with blue lines to our customers.
Sorry, but chances are you wont be able to do anything yourself, best to take it to where you bought it from (or ring the manufacturer) to get a replacement (if its still under warranty), else you may need to purchase a new one.
Dec 16, 2008 | Acer Computers & Internet
Acer 1716 17 inch LCD monitor, screen fuzzy w/white lines at rt
Common problem.
There are 8 small VRAM BGA chips.
1 or 2 of them needs REFLOW.
Basically board service.
Dec 16, 2008 | Acer AL1716 17" LCD Monitor
Acer H233H bmid Monitor Logo
218 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
