Question about Velodyne DPS-10 Subwoofer
Subwoofer DPS-10 == works great for a period of time then- it starts a pulsating hum. Sometimes it happens after 30 minutes and other times it is a couple of hours before it starts.
  • 10,319 Answers
I also had the same problem, I bought final scratch used with 2 ground loop isolators, even with those I still had the buzz. After buying the
3-to-2 prong 110 volt plug everything is perfect
I got mine and homedepot
Posted on Mar 20, 2011
When does your heart work the hardest
Work is often defined as how much volume or weight is carried, for how far in a given period of time. Examples: Move 1000 Lbs 10 feet in 10 minutes, Now move it 20 feet in 10 min - you've done twice the work. Or, 2000 lbs 10 feet in 10 minutes = twice the work. 1000 lbs, 10 feet in 5 minutes = twice the work.
So, a good measure for a heart would be how much blood is pumped in a period of time. The amount of blood in each beat doesn't really change, this distance is always the same, so how often it happens is a pretty good indicator. Simplified, you could say that the heart does the most work when it beats the fastest. Run for 130 beats per minute is 4 times the work of say, sleeping at 30 beats in a minute. Anything that raises yur heart rate to the highest would be the most work.
Apr 09, 2014 | Computers & Internet
Velodyne dps 10 rca hums but wired is fine
The issue a floating ground that causes the hum you are talking about. What are you connecting it to that causes the hum?
Jan 07, 2014 | Velodyne DPS-10 Subwoofer
My Velodyne DPS-10 subwoofer hums when you plug in the RCA cable. The hum increases in volume when you touch the rear metal panel.
hi,
You have to check the RCA cable to the sub woofer. The RCA cabe have two connections inside it, one is for gain and the other is for ground sheild. If the ground sheild is broken then there will be hum from the sub woofer and it will increase if you touch the ground (rear metal pannel is connected to the ground). Replace the cable and check it again.
ok
Jul 17, 2011 | Velodyne DPS-10 Subwoofer
Works great for a period of time then- it starts a pulsating hum. Sometimes it happens after 30 minutes and other times it is a couple of hours before it starts.
it sounds like a bad sub woofer amplifer, as the unit heats up the capacitors start to leak and the amp will try to shut down. it would depend on how hard you are driving it, (heavy bass versus light bass) that would cause it to fail sooner than later. You need to replace the internal amp
Mar 20, 2011 | Velodyne DPS-10 Subwoofer
Humming sound when on/off
humming sound when on is usual if the volume is turned up.
humming sound the same when on or off could be transformer plates fluxing.
if loud recommend replacement of power supply.
if ok then recommend unplugging the device after use.
Nov 13, 2009 | Velodyne DPS-10 Subwoofer
Power Light, Pulsating Level Control, Blows Fuses
you may of caused a short in the connections or it got moisture why in storge if so the hole subwoofer is screwed
Jun 07, 2009 | Infinity BASSLINK Car Subwoofer
Loud noise from subwoofer on standby or while playing music
Hi There, Please advise us what happens when you turn off the sub woofer is the hum still there....??
From YUBEUT.
Nov 27, 2007 | Teac CD-X8 CD Shelf System
Open Questions:
Velodyne DPS-10 Subwoofer Logo
119 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
