Question about Pride New Jazzy 600 Power Wheelchair by Mobility
When i turn the power on, the lights on the battery and the speed keep flashing very quickly. they do not stop.
  • 692 Answers
Archie the only thing I can think that causes this problem is one or both of the motors are in freewheel. Check that both levers are in drive mode. then turn the chair on to see if the flashing stops if not call Pride @ 1-800-800-8586 ask for Jazzy tech support and explain the problem They should be able to lead you in the right direction Hope this helps you
Posted on Mar 21, 2011
The blue power light and the blue and red battery lights keep flashing and won't stop Why?
Sounds like the battery itself is going bad and needs to be replaced. The blinking lights are a code that you can find at the OEM website and it will tell you exactly what is going on..
Feb 01, 2014 | Acer C7 Chromebook
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
    May 04, 2012 | 1994 Nissan Maxima
    Fully charged the choppers battery,the controller has all new batteries,turned on the chopper power switch,turn on te controller power switch and wait till light stops flashing.push on the power controll...
    The light will keep flashing unless you are on the correct channel A B or C and you hit the "Light" button on the front of the unit.
    As far as the high speed take offs I suggest identifying which A B or C setting is correct for your copter. In order to do this turn off the RC controller. Set the Selector switch to "A" move the left joystick "throttle" half way up and then turn on the power. Assuming that the copter is still ON it will either fire up or do nothing. If it does nothing try the same sequence with the selector switch set to "B" and try again. If nothing try "C".
    Now, as far as the rapid accelleration, I read one online comment that indicated that there is some type of "programming" sequence that the unit learns by pushing the left joystick throttle all the way forward and then back to zero when you start to fly it. So after the first "blast off" set the copter back down or even hold it in you hand by grasping the the landing runners and move the throttle forward until the rotor spin up and it lifts off. In your hand it is easier to keep it from going up too quickly.
    Aug 21, 2011 | JCPenney Gyropter RC Helicopter
    I bought a World Tech Toys ZX-A68690 helicopter and I cant get it to work. I charged the battery pack as outlined in the operation manual. I installed the "AA" Duracel batteries in the...
    Try turning the controller power on ( before turning on the chopper) and then quickly moving the left throttle stick up to the fastest setting and then immediately back to the slowest speed setting...The flashing should stop. This calibrates the remote throttle range.
    Turn on the helicopter and you should be OK
    Jun 01, 2011 | Worldtech Devices Toys
    Right out of the box yiboo uj 381 r/c helicopter. Copter charged and new batteries in the controller. Lights flash on the copter and flashing light on the controller but nothing happens. what's wrong
    did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
    Dec 25, 2010 | Toys
    Have a jazzy 1113. The speed profile lights flash then the chair shuts off. The batteries show full.
    The flash of the speed lights indicate that you are in the charger inhibit mode and if the charger is not plugged in then you have a problem that needs to be checked by a tech or your provider that sold you your chair Sorry I don't have a quick fix
    Sep 25, 2010 | Pride Jazzy 1113 ATS Indoor Power...
    Canon Macro Settings for 100mm lens and Sunpak 12R ring flash
    Firstly, be sure to check flash voltage. Your 30D may accept max 6V so that your camera can be shot if the flash unit has higher voltage than 6V.
    1. Use low ISO to keep low noise....around f/8 or more depends on your need and how much DOF you want.....Set the shutter speed around 1/125 to your max speed to stop any movement (your subject or camera itself shaking).
    2. Above is set in Manual mode (iso100, f/8 1/125 or 1/250), then you just need to leave the flash to work in TTL mode.
    3. It needs battery, the connection is for syncing to trigger and release a proper flash power (in TTL mode).
    Hope this help!
    Mar 26, 2009 | Sunpak DX-8R TTL Ring Light Flash
    Park lights and dash lights won't stop flashing
    There is a small black box under dash by steering column that has a little red button on it. Push that button and it will reset the alarm. Whenever the power is removed from the system it will trigger that alarm and flash your lights. Easy quick fix. Box is about 4" x4" and just to the left of the column. Good luck and have a great day.
    Mar 14, 2009 | 1998 Subaru Legacy
    Gateway MX6438 will not power on
    if your battery is dead and your not able to use the adapter to keep it going, its probably a dead ac adapter. is the light where its connected ? light on the box (if it has one), the outlet you are plugged into have power to it ? try another plug
    Dec 29, 2008 | Gateway MT6730 Notebook PC
    Under cycle setting the quick rinse light keeps flashing and dishwasher does not run.
    Hey Jim, if your model starts with 665 there was a service flash on this unit concerning your problem. SF-22-715. Dishwasher stops in mid cycle. The control board was redesigned to eliminate this problem. The service flash states that if only one indicator light is blinking it's usually a stuck or shorted keypad. I would check with Sears and see if you are covered under this service flash. Catriver...post back.
    Aug 28, 2006 | Kenmore 24 in. 15689 Built-in Dishwasher
    Pride New Jazzy 600 Power Wheelchair by Mobility Logo
    126 people viewed this question
    Top Pride Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Colin Taylor
    Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
