Question about Velodyne DPS-10 Subwoofer
Works great for a period of time then- it starts a pulsating hum. Sometimes it happens after 30 minutes and other times it is a couple of hours before it starts.
  • 604 Answers
It sounds like a bad sub woofer amplifer, as the unit heats up the capacitors start to leak and the amp will try to shut down. it would depend on how hard you are driving it, (heavy bass versus light bass) that would cause it to fail sooner than later. You need to replace the internal amp
Posted on Mar 21, 2011
My Gateway NV53 has just stopped charing period. The Computer doesn't even reconginize that the charge cord is in. Can someone help?
This happened to me a couple times, the first time, I had to send my computer back to the factory because the DC board was defective but the second time I just had to leave my charger unplugged for an hour or so and then it worked fine. Sometimes, the charger will heat up to a point where it shuts itself off before it literally starts to melt.
Hope this helps, Nathan Taylor
Jul 21, 2011 | Gateway NV5378u Notebook
How long does the soak programme last?
For this machine the length of time of between 30 minutes and 2 hours can be programmed in 30 minute increments for the soak process.
The machine is set ex works with a soak period of 2 hours.
To programme in a different soak period see "Programmable functions - Soak" in your user manual. See Page 59.
Oct 16, 2009 | Miele Novotronic Premier 500 Front Load...
It starts then it stalls, sometimes it starts right up some times it doesn
It could be the Crankshaft Position Sensor - My 1993 Bonneville with a 3.8 had the same issue, I replaced that and it works great now.
It had codes:
17, and 18 I think, or maybe 19 stored. Which was Cam Position sensor, and Crank position sensor problem.
The crankshaft position sensor is easy to replace, if you have access to a pulley puller, some tools and a jack or lift. Some motors need a special tool for an adjustable thing, but most dont have that anymore as I think they recalled it and replaced it on all.
I think they run about 30-60 for a new one, and takes about an hour to replace.
If it is intermittent start problem that may be it. Mine would start fine for a while, then sometimes after Id turn it off, it would just crank and crank, It would start after waiting about 5-30 mintues, while trying to crank it every couple minutes. When driving down the road, it sometimes would stall when turning or stopping.
Hope this helps - Jarett *mechanic with 14 years of experience
Jun 22, 2009 | 1992 Pontiac Grand Am
Toshiba Satellite M45-S265 Periodic Freezing, resumes, clock stop
do a virus scan
in add/remove uninstall any programs you no longer use
then do a disk defrag
then a scan disk
have you made any changes to system
please let me know if this has helped
don't forget to rate
Nov 30, 2008 | Toshiba Satellite M45-S265 Notebook
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Kenmore series Model # 69051fan squeaks
evap. fan mtr are always tricky if the are intermittent. you need to record the sound when it happens and make sure it is coming from the freezer. make a record of how many times it happens in a 24hr period all this will help the tech. and don't take no for a answer from the tech most service calls are good for 30 days
Jun 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
Velodyne DPS-10 Subwoofer Logo
247 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
