Please,my computer is having a problem since 4 days ago, I could not play cd or dvd because,the cd or dvd drives did not appear again on my computer please what can i do to play again or to see this drives again
    Master:
  • 525 Answers
Reintall the drivers for your disc drives and reintall the driver for your ide controller.
Posted on Mar 21, 2011
A while ago, my laptop's DVD drive stopped reading CDs. A after a few attempts , it displays the CD/DVD as an empty one. The CDs are not empty or too scratched because I tried them on a different computer...
Hello there!
Please note that a CD-ROM drive can read and in some cases write to a CD inserted into it. This is done by means of a fragile laser mechanism that scans the surface of the disc as it spins at high speed inside the drive. Drive failure can occure from a scratched laser eye, mechanical failure, overheating, or simply years of use. You will want to ensure the drive is actually broken before buying a new one as replacement or send it for a repair.
Please follow these easy steps:
1. Open the CD drive tray and insert a CD. If you have a tray that opens by pushing a button, push the button. For slot drives, try to slide the CD in. On slot drives, if the CD will not go in fully, the drive is not getting power.
2. Wait and listen for a "whirring" sound from the drive after the CD is in and the drive tray is pushed in. This may take a few seconds.
3. Look at the status light on the front of the drive if one is present. It should be blinking to indicate that the device is reading the CD.
4. Replace the first CD with another one in case the first CD is damaged or unreadable. Repeat steps 1 through 3 with the second CD.
5. Wait to see if anything comes up on the pc screen indicating the CD is being read or run. A notification may appear asking if you want to play the CD or run the software. This indicates a functioning drive.
6. Click on "Start" followed by "My Computer" and locate the CD-ROM drive usually labeled as "D:/" or "E:/". Double click on it. If the CD drive makes no noise or an error message appears on screen indicating the disc can not be read, the drive may be broken.
If an error message appears indicating that the CD-Rom drivers are missing this may indicate a software issue and not a broken drive.
Regards,
fossildude
Mar 15, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Cd/dvd rom will not play or burn
you need a cd\dvd rw to be able to burn as for wont play\read
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no 4 for australia
hope this helps
Nov 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
Computer does not respond when installing music cd
Go to Control panel, Next click on the hardware tab. Find your CD drive listed up close to the top. Highlight the CD drive and click on uninstall. Reboot the system and the system will automatically re-install the drivers. See if that will work.
Apr 01, 2009 | Dell Dimension 4700 PC Desktop
My dvd drive in my computer won't play dvds
1. Completely remove any dvd/cd player/burner softwares (i.e. Nero, Power DVD, etc.).
2. Go to device manager and remove your DVD/CD device from the device list
3. Restart you laptop
4. Windows will then try to reinstall the device drivers again for the DVD drive.
5. After another restart, then reinstall your dvd softwares again.
Nov 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba S1800-514. WILL NOT PLAY ANY DVD.S
Here is the solution Go to My Computer right click on CD/DVD drive (It might appear DVD-RAM as well) click on properties and go to recording tab "Check" the enable CD recording on this device. Click on apply and restart the computer. It will recognize standard CD/DVDs
Dec 29, 2007 | Office Equipment & Supplies
Dvd rom
You can try the steps below to fix the issue.
Edit the registry:-
1. Click Start, and click Run.
2. Type regedit in the Open box, and click OK.
3. In Registry Editor, click the plus (+) sign next to each folder name to expand the following registry path:
4. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
5. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
6. In the right pane, right-click Upper Filters, and click Delete.
7. Click yes when prompted to delete the registry value.
8. In the right pane, right-click Lower Filters, and click Delete.
9. Click yes again.
10.Close the window and restart the computer
Please do not forget to rate the solution.
Regards,
Musheer.
Nov 10, 2007 | Sony (DWQ58A) DVD RW Dual Layer Burner
DVR-111D dvd/cd writers
hmmm, this is unusual, it appears to be an incompatibility with the DVD software, as everything else seems to work may I suggest that you upgrade your DVD software for a later version.
May 23, 2007 | Pioneer 16X DVD Drive Burner (Model...
Disk drive
There may have been a Windows update that corruptdated one of your Windows Media Player files. Check for spyware or a virus. WMP is usually an avenue for thay sort of thing. Check for updats to all software involved. You may also consider doing a firmware update if they have one. Good Luck, Tim
Feb 08, 2007 | Toshiba Satellite A100-S8111TD Notebook
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
