Question about Vacuums
I have a Hoover UH70130 windtunnel vaccum I want to know if ther is a reset button to get it started again. Bought it at Costco about 3 months ago now it is not working
  • 97 Answers
SOURCE: Hoover Windtunnel shuts off
Sounds like you have a clog, which is a fairly common problem with these.
Check the air inlet immediately aft of the brushroll for clogs, then make sure the main wand and hose are also clear. If you have the machine on, check at the end of the hose for suction. This is a fairly common problem for all uprights with tools on board. Their airflow is very low, so they tend to clog up easily and then overheat the motor.
-R
Posted on Oct 01, 2008
SOURCE: auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Posted on Jul 09, 2009
  • 430 Answers
SOURCE: I bought Hoover Wind tunnel central vacuum 2 weeks
There is a hinged bracket for this unit which has a 5" bolt through it. It comes from CanaVac who manufactures under label. If you cannot find this large U shaped bracket on the body or in the bucket, either return to COSTO or call Canavac and explain. A used bracket from an old Canavac will fit, nothing else will. If Costco is sold out you will not likely get one through a Hoover service center since they just don't break and it is a newer body style for Hoover made under private label.. A Canavac dealer might have one around
FYI if you got this unit at $200 off you got good value, if you paid full price and need to wait for a bracket, shop around for a different brand. While the unit and tools are good , the Hoover power head is the Achilles heal on this package. If you use it more than an hour a week , you will wear it out within 3-5 years as it is their light duty head.
If you have the bracket , hang the unit on a double stud if possible or 3/4 plywood braced across two studs. Leave 24-36 inches slack in your low voltage wire at the motor and coil around a pencil or long philips screwdriver, making it phone cord style... your wife and neighbors will think you are a pro......
Post back if you need more info.
Posted on Oct 16, 2009
  • 91 Answers
SOURCE: Hoover U5780-900 Windtunnel a month 1/2 old just
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Posted on Feb 21, 2010
VacuumRepair
  • 438 Answers
SOURCE: I have hoover WindTunnel Self Propelled Vacuum
Greetings from GoVacuum,
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at chris.jones@govacuum.com if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change
Thank you very much!
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
Where do i check for the fuse on my hoover windtunnel vaccum
Most Windtunnels do not have a fuse but have a thermal reset in the motor which shuts the motor off it overheats.
Jan 23, 2018 | Hoover Vacuums
Hoover has no power. Is there a reset button?
Important Notice Regarding Hoover WindTunnel Series REWIND Bagless Upright... I found some interesting reading here that could pertain to you. Thank you and leave feedback for I am new at this. James please have a great day!
Jul 14, 2016 | Hoover U6437-900 / U6439-900 Windtunnel...
I cant get my hoover vaccum brush to spin
First be sure the switch/circuit breaker on top of the nozzle is on. The brush also will not turn unless the handle is released and tilted back. This model of Hoover has a gear drive to turn the brushes. This was VERY prone to problems, and Hoover discontinued making replacement parts for it several years ago.
Mar 18, 2011 | Hoover U8147-900 WindTunnel V2 Bagless...
I just bought a Hoover Windtunnel upright with bag, #U6485100. When installing the handle there was tape over the top with instructions do no remove until assembled. After assembling (screwing in the...
Be sure the on/off button and the power drive button are both in the OFF position before installing the handle. The actual switch inside must also be in the OFF position.
Feb 27, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
I bought it in may , I can honestly say , it is THE worst vaccum
There are several filters on bag-less vacuums that need to be cleaned. Dig out your owners manual or open the one below. See section 3 for filters and maintenance. If you are vacuuming a house bigger than about 1500 square feet, you should be cleaning the filters every other use. Personally, after using a bagless for a couple of months, I went back to my bagged vacuum.
http://www.hoover.com/pdfs/manuals/U6630900.pdf
Dec 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hello! Hoover WindTunnel broken! aRGGHHH
I would definitely check out the epoxy route.
Jun 14, 2017 | Hoover U6630-900 WindTunnel Bagless...
Shuts off after 15min
the motor protection 1st has to be replaced
Mar 06, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
I have a hoover windtunnel upright vacuum bought it a few months ago and now the brush spinning stopped working.
You probably have a broken belt, or the belt came off. The Self Propel Windtunnel has an issue with the pulley that tightens the V-belt in place getting stuck and needs to be taken apart and released, but most likely its just the belt. They should be replaced every 6 months or so, and the part number is usually on the serial tag of the machine.
Nov 22, 2008 | Hoover Vacuums
No suction
have u checked all of the filters. I know that when not all the filters r clean the machine will turn on but then it will sound louder and still have no suction. Most times there is a filter under dirt container thats sits above motor and if this filter is not clean the motor cannot breath. Thus no suction
Sep 29, 2008 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
