Question about Frigidaire Dryers
My electric dryer makes a loud squeal while drying? what is wrong
    Genius:
  • 1,400 Answers
Hello
Sounds like the belt is slipping from wear.Remove rear panel of dryer and replace the belt.
Its not very hard to do.
Belt wraps wround the drum and a pully on the motor,there may be an idler pully also.
Check these pullys and motor for free turning while the belt is off.
Posted on Mar 20, 2011
Dryer makes a loud squealing noise when I try to dry a load of clothes, towels, anything
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 11, 2011 | General Electric G.E. DBXR300EGWS 6.0 Cu....
ELectric dryer on any setting makes a "Rubbing or squealing"sound when turned on and inside "drum" is rotating. Does heat up, just very loud/ Whats wrong?
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 21, 2010 | Frigidaire Electric Dryer
SQUEALING DRYER WHILDE DRYER IS DRYING CLOTHES THRU OUT THE CYCLE ITS SO LOUD THE NEIGHBORS HAVE MOVED OUT!
spray belt with wd40 may be able to access it if you tilt or you will have to remove cover bring your model up online sears to see how to dissamble
Jan 16, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
THE DRYER STARTED MAKING A SQUEALING NOISE AND THEN IT STOPPED AND WOULD START AGAIN AND SOMETIMES IT WOULDN'T MAKE A NOISE BUT NOW IT'S SO LOUD THAT YOU CAN'T STAND TO HAVE IT ON.
you may have to take it apart and check two things...
1. the motor on dryers can get pluged with dust and lint and dry out. the motor bearings may simply be dry. it might be too late for the motor, but you could try lubing the motor bearings and at least stop the squeal for a while.
2. remove the drum and lubricate the wheels or bearings that the drum rides on.
lubricate all rollers and belt guides as well.
hope this helps..........jay
Mar 21, 2009 | GE DBSR453EBWW Electric Dryer
I have a Maytag Dryer MDE9806AYW Intelli Dry SQUEALS
Yes its worth repairing, it sounds like a simple fix, could be pulley, or seal replacement but for the price of some machine oil, or part, well worth it. The intelli dry pulls apart from front, with the door and top is hinged. A little time consumeing but I think still worth it.
Feb 04, 2009 | GE DBSR453EBWW Electric Dryer
Dryer makes a loud squeaking/squealing noise while drying.
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
64 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
