Question about Hoover Vacuums
My brand-new Hoover Windtunnel T-Series Pet Rewind Bagless vac simply shut off while I was using it and now I can't get it to turn back on. I've emptied the dirt collection bin and let the unit sit unplugged for 30 minutes to reset the Thermal Protector as per the manual. I've even tried a few different outlets just in case a fuse got tripped, but the vac still won't turn on. What happened? Do I need to return this vac to the store? I just bought it 5 hours ago.
    Top Expert:
  • Hoover Master
  • 41,697 Answers
Return it as defective
Posted on Jun 10, 2017
  • 126 Answers
SOURCE: hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Posted on Jan 20, 2008
SOURCE: Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Posted on Mar 18, 2008
  • 199 Answers
SOURCE: My hoover U5720950 windtunnel bagless vacuum loses
when you lower the handel it is pinching the vaccume line constricting suction
Posted on Jun 11, 2009
  • 8404 Answers
SOURCE: how do I clean the lifetime hepa filter
Check with the manufacturer. I have always had good response from Hoover.
Posted on Sep 23, 2009
Vac Belts
  • 701 Answers
SOURCE: Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Posted on Dec 23, 2009
Testimonial: "Replaced the belts-- works GREAT!!! Thanks"
Hoover has no power. Is there a reset button?
Important Notice Regarding Hoover WindTunnel Series REWIND Bagless Upright... I found some interesting reading here that could pertain to you. Thank you and leave feedback for I am new at this. James please have a great day!
Jul 14, 2016 | Hoover U6437-900 / U6439-900 Windtunnel...
How do i remove the rewinder on a Hoover UH70120
Since you felt the need to ask this question, you are obviously not qualified for this level of repair. Take it to your local vac repair shop. If you have had your machine for less than 1 year it is still under warranty. If it is over 1 year old it is probably not worth fixing. New Hoovers are designed to last only one year and toss them ( as are most all bagless vacs for that matter ).
Jun 25, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
Can you use a Bissel 6594 Series vacuum belt on a Hoover UH71003 vacuum?
yes. The hoover belt is only slightly longer but it shouldn't cause a problem.
Oct 18, 2013 | Hoover Elite Rewind Pet Bagless Upright,...
The cord rewind pedal and metal piece came off and I can't get it back on. It doesn't appear broken.
It's plastic with chrome paint, not metal. Take it to a vac repair shop and have them fix it. You may break the tabs if you force it.
Oct 14, 2013 | Hoover UH70120 WindTunnel TSeries Rewind...
Belt will not stay on
Those machines have the belts on them at production.
You can read about this
www.vacuummedic.com/blog/2012/10/09/my-brand-new-vacuum-doesnt-work/
Change the belt! Good as New!
Good Luck
The Vac Dr.
Dec 21, 2012 | Hoover Elite Rewind Bagless Upright Vacuum...
Power cord will not come out
There is probably a crossed cord in the rewinder. I am not sure but if you can get into the rewinder you can free up the cord it should go, hope this helps. Chris
Feb 07, 2011 | Hoover UH70120 WindTunnel TSeries Rewind...
Cord rewind hoover s3765
Remove the 5 Phillips-head screws carefully without stripping the heads. There are 2 at the front bottom, 2 at the top back (above the wheels), and 1 at the back beneath the dustbin. After the screws are loosened/removed, you can remove the top cover of the vacuum (be careful with the attached wiring harness). Then remove the black plastic cover over the cord rewind wheel, and you can easily remove the wheel. Pull the cord out a bit to give yourself some slack. You should be able to free the jammed cord and then reassemble the vac.
Nov 14, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover Wind Tunnel bagless- issue with turning on
Have you tried to plug the vaccuum in another outlet that is on another breaker? It could be the vaccuum tripped the breaker. Turn the breaker back on. The manual mentions the thermal protector could have been activated. If this happened it resets and your vac should run after 30 minutes. I have a Widepath Tempo and it has tripped the surge protector. If this is the problem try turning some things off that are also on that breaker/outlet, or unplug them when you use the vac.
Jan 04, 2009 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
71 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
