Question about Frigidaire Refrigerators
FPCI-170T-7 Frigidaire refrigerator. I need detailed instructions on how to replace the light switch. I have removed 2 screws in the trim and seems not to have had any effect on the trim. Thanks in advance tommy
  • 56 Answers
SOURCE: 650 refrigerator door light switch
Go to Sub Zero.com and click the showroom locator on the top left of the screen. This will take you to a locator to find the authorized parts distributor for your area I beleive the part number is 3060140 . Once you have the part remove the three phillips head screws that hold the grill in place this is assuming you don't have the louvered grill. There is a grey power cord with a white quick connect seperate this or turn the power off at the circuit breaker. You will be working on live electricity if you don't.Not good for yu life expectancy. There is one more phillips head screw for the cover of the two switches. The light switch has a white back and the fan switch has a black one. Remove the two wires then push it down and slip the new one in. Replace all that you took off. While you have the grill off vacuum the condensor.
Posted on Dec 02, 2008
  • 333 Answers
SOURCE: how do you remove the light switch on a whirlpool refrigerator
The light switch just pops out. Take a butter knife or something of that sort and put it on on end of the switch and poush towards the center of the switch whilr prying it up. It should pop out. I hope this helps. Don't forget to rate my answer.
Posted on Feb 06, 2009
  • 360 Answers
SOURCE: How old is my refrigerator?
Here is a --->link<--- to download the manual for your unit.
this --->link<--- will allow you the ask Frigidaire what year the unit was manufactured.
hope this helps
clarkco
Posted on Feb 17, 2009
  • 27 Answers
SOURCE: replace light switch in frigidaire freezer
it is very simple, disconnect power supply of your freezer. take two flat screw drivers and pull the defective light switch, disconnect the wires and fix it to the new switch and press the switch back to is original possition
Posted on Mar 06, 2009
outdoorsman5
  • 631 Answers
SOURCE: What is the volume of the old Frigidaire
Here is a link that might help.
http://www.appliancepartspros.com/partsearch/
Posted on Jul 28, 2009
Handles loose on Frigidaire fridge doors
Jeff, If you can not see any visible screws, look for molded removable trim caps on the handle, remove and tighten screws. If no trim caps then your handle is probably mounted to fridge with screws in slotted slide, which get slid off by pulling straight up on handle, normally takes a lot of force to slide up and out. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix loose Refrigerator Handle
How To Fix Your GE Refrigerator Handle by removing the cap and tightening...
Refrigerator Door Handle How To Replace
Refrigerator Repair Replacing the Door Handle Frigidaire Part 218428101
Jul 10, 2016 | Frigidaire Refrigerators
How do I raise the level of my refrigerator door to be even with freezer door?
Thank you for your inquiry, Leland Dodd!
I see that you are having difficulty in raising the level on your Frigidaire refrigerator, FGHC2331PF. I have reviewed your manual and there are two types of adjustment for either front rollers or lower hinge. If you are having issues with adjusting the doors or leveling your refrigerator I would recommend having a professional technician out to properly level your refrigerator. Best of luck! -Matt
Dec 03, 2014 | Frigidaire FGHC2331PF Gallery 23 Cu. Ft....
How do you find the defrost timer on custom imperial model number FPCI-170T-7.
Hey Robert Bouie, thank you for your post!
I understand that you are searching for the defrost timer inside of your Frigidaire imperial, FPCI-170T-7. I have researched the model number provided and I show that it is an older model. In order to provide you proper location of your defrost timer I would seek assistance from a professional. I hope this is helpful. -Matt
Oct 01, 2014 | Frigidaire Refrigerators
Frigidaire custom imperial 170 manual
replacement compressor for frigidaire refrigerator freezer Custom imperial FPCI-230v3 (20.3 ft vol)
replacement evaporator fan and condenser fan
Jun 11, 2012 | Frigidaire Refrigerators
Instructions how to step by step replace ignition lock cylindor for an 1999 oldsmobile intrigue
1999 Oldsmobile Intrigue
IGNITION SWITCH AND LOCK CYLINDER REPLACEMENT
1. Disconnect battery
2. Disable Supplemental Restraint System (Airbags)
3. Remove traction control switch from rear of center console plate
4. Open console lid and remove screws at front of console
5. Pull console plate up to release clips and slide over shifter
6. Pull rearward to release clips retaining instrument panel accessory trim plate to instrument panel
7. Remove screws attaching radio to instrument panel
8. Disconnect electrical connectors and remove radio
9. Take down instrument panel hush panels and disconnect courtesy lights. Remove hush panels
10. Remove knee bolster and knee bolster bracket from driver's side below steering column
11. Remove screws from IPC trim plate
12. Pull out instrument panel cluster trim plate to release from retainers
13. Remove trip odometer and reset switch from IPC trim plate
14. Remove IPC trim plate
15. Remove screws from IPC and pull IPC out
16. Disconnect electrical connectors from IPC and remove IPC from the instrument panel
17. Disconnect ignition switch connectors
18. Turn ignition switch to the ACC position and remove park lock cable from ignition switch
19. Turn ignition switch to ON position
20. Depress and hold locking tab on right side of ignition switch with a small, flat-bladed screwdriver and pull ignition lock cylinder from ignition switch
21. Remove ignition switch bezel from ignition lock cylinder
22. Remove screws attaching ignition switch to bracket
23. Remove ignition switch through the IPC opening
24. To install, reverse procedure
Apr 04, 2011 | 1999 Oldsmobile Intrigue
Were does the LH mirror on a 2011 f-250 connect. Removed mirror but disconnect is located some were in door or body. need to know what needs to be removed to gain access
  1. Remove the front door trim panel.
  1. Position aside the front door watershield to gain access to the exterior rear view mirror control switch electrical connector.
4.Disconnect the exterior rear view mirror control switch electrical connector
as you see you have to remove the door panel to have access to the electrical connector in case that you dont know how to do it here are the instructions
NOTE: Left front door trim panel shown, right front door trim panel similar.
  1. Remove the sail panel.
    • If equipped, disconnect the electrical connector
  2. If equipped, lift up and remove the exterior rear view mirror control switch panel.
    • Disconnect the electrical connector.
  1. If equipped, lift up and remove the window control switch panel.
  1. If equipped, remove the window regulator handle.
    1. Position the window regulator handle cover aside.
    1. Remove the window regulator handle screw and regulator handle
5.Remove the door trim panel center screw cover
6.Remove the 2 door trim panel center screws
7.Remove the 2 door trim panel lower screws
  1. NOTICE: Do not pull directly outward on front door trim panel as damage will occur.
    • Lift upward to remove the front door trim panel.
  1. NOTICE: Insert the lower panel tabs first or they can break when installing the front door trim panel.
    To install, reverse the removal procedure
Feb 20, 2011 | 2011 Ford F-250 Super Duty
How do you replace the headlight bulb in a 2007 bmw 328i?
You have to remove the bumper first...
Tools Required:
- socket wrench/socket kit
- 8mm socket
- 10mm socket
- flathead screwdriver
- flathead stubby
- torx driver set
Optional Tools:
- car jack
- monkey (to hold your work lights)
Instructions:
- jack up car (optional)
- At least jack up one side of the car
1) Remove 4 screws on top of bumper ( under hood, above kidney grills)
2) Remove 2 screws in each wheel-well, and clip bumper trim away from wheel-well trim
3)Push wheel-well trim away so you can unfasten 2 screws inside that hold top part of bumper to the car on each side
4) Release about 7 Screws on bottom of bumper from underneath
5) Remove bumper by uncliping each side and then pulling bumper forward
Foglights will stay in place. simply disconnect the cable.
After you remove the bumper and unplug the Foglights
1) To remove the lights you also need to remove the bracket that hold the lights
2) Remove the blots on the bracket and top of headlight.
Installation is in the reverse of removal...
Oct 21, 2010 | 2007 BMW 328xi Sports Wagon
My light that illuminates the compass and milage went out on my 2004 f150. any idea how to change the bulb
The dealer will tell you it is a cluster replacement, but there actually is a bulb back there ( if you can see the numbers, they are just not illuminated ).
Removing the dash can be time consuming, but starting with the knee panel, remove the screws at the bottom. This will expose the screws to the bottom of the dash. Next remove the main headlamp switch trim, and there are 2 ( 3 ) screws behind this that also need to be removed to get the dash trim out.
Once the dash trim is out, you will see the screws holding the cluster in. Remove these, and you can lay the dash on a towel on the steering wheel column. The bulb holder is one of those twist in from the back types, that some auto stores carry ( they are not just 194 or 39 bulbs ).
Time consuming, and Ford used just about every bolt head size from 7 to 10 back there I seem to recall.
Oct 13, 2009 | 2005 Ford F-150
I need to replace passenger side mirror on 97 ford expedition
Both above answers are not right... I just replaced the Pass side power mirror assembly on my 97 Expedition. No heat, no directional.
The inside door panel must come off.
1. pry off interior triangular plastic trim piece inside of door at mirror area. Remove door panel screw at this area.
2. Pry off power window switch panel and remove door panel screw at this area.
3.Remove interior door light cover and remove screw at this area.
4. Remove plastic cover at door handle.
5. The interior door panel can now be lifted up to release it from it's fasteners.
6. Disconnect light and push power window switch assembly through the door panel and it can be set aside.
7. Disconnect mirror power at coupler.
8 Loosen three mirror mounting screws with 7/16 socket. DO NOT unscrew completely.. the will fall down the door cavity. Use a round magnet on holder to remove the screws completely.
9.Thread electrical connection into door panel and install mirror.
10. Smile when mirror works and drink a beer!
rayman
Dec 27, 2008 | 1997 Ford Expedition
Refrigerators Logo
245 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
