The heat and fan are running great, but in Florida it's now ac. time. The compressor does not come on. The unit is just blowing warm air. The ac hasn't been used since last November, at which time it cooled just fine.
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Mar 20, 2011
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Bought the cavalier had no ac/ but has great fan blowing it's just hot, defrost everything runs normal mulitiple speed////recharged w r134 blew ice cold almost 3 months went out again slowly. Stopped at...
I,t sounds like you had a leak, and pulled air into the system. This calls for professional servicing. Whenever there's a leak in a refrigeration system, air and sometimes other noncondensables get pulled into the system. They don't belong there. They cause heat and high pressure in the condenser, and will eventually destroy the compressor. The system needs dehydration and evacuation before charging. That's after all leaks have been repaired.
Aug 26, 2013 | Heating & Cooling
Sometimes, when the inside blower shuts down, the
I was leaning towards a bad contactor. Either sticking sometimes or not making good contact. I would inspect the contactor for pits or burn marks near the contacts. DO SO WITH POWER OFF of course...but, what's the reset button you are referring to?? I'm assuming this is a heat pump, please send model number!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 06, 2017 | Ruud UAKA060 Air Conditioner
Sometimes, when the inside blower shuts down, the outside compressor and fan motor continue to run for some time. Other times, when the inside fan motor is running, the outside fan and compressor motors...
The thermostat has a timer on the on- cycle (5 min delay for the outside unit and blower inside) if you are not gonna call a service guy then ( for $25) you can go to homedepot (whatever you got out there) and buy a honeywell vertical digital heat and ac t'stat.
this one doesnt require you to set it up for a particular application. this may solve your problem. but as for warm air out of the registers you need a service guy to check that
Mar 27, 2010 | Ruud UAKA060 Air Conditioner
Central heat does not blow hot air, just warm air weakly
Sounds like some of the elements are not working. You being in Florida they may not have put very many elements in. It was 61 degrees last week. I know because I'm a Dolphin Fan. You will need a current sensing meter to check the elements.
Jan 04, 2010 | Heating & Cooling
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
Kenmore AC compressor on and off while outside unit fan running
If the out door fan keeps running and the compressor cycles off that would be the overload in the compressor.
What keeps the windings cool is the refrigerant back to the compressor.
For the overload to cycle it would have to be either not enough cooling back to the compressor or high amp draw, which could be the metering device (txv or orifice) or low on charge, or other things would be a bad capacitor, sometimes a bad start relay not staying open, when compressor gets up to speed or anything causing the compressor to draw high amps.
To check the refrigerant, he needs to check the superheat at the compressor it should be appoximately 12° to15°, and next time the compressor goes off if you shut the power off and feel the top of the compressor and if it's hot 130° or higher it's probably refrigerant.
Aug 14, 2009 | Heating & Cooling
Dometic AC that the fan shuts off but the compressor keeps running
call dometic dealer. I hear they have a bad circuit board that is replaced.
Jun 02, 2009 | Dometic Rooftop RV Air Conditioner
With ac running cold, blows warm when truck is stopped
I have a dodge 2007 ram 1500...most likely its an RPM issue. The compressor requires a certain RPM to maintain the required pressurized vapor.
Apr 29, 2009 | Heating & Cooling
Reverse unit. Heater only blows air, not warm air
If you have a reverse cycle unit (heat pump) your compressor and your fan should be running. You need to determine if your compressor is running.
Nov 07, 2007 | Kenmore 71121 Air Conditioner
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
