Question about Thermos BOTTLE INTAK BPA FREE HYDRATI HP4000GR6
I have a intak hydration bottle. On the clear lid, there is a round rubber disk that has a protruding tip. This prevents water from leaking. Somehow mine fell out and I did not notice. Can I get a replacement? Thank you in advance. Patty Tschetter
Is freezing water in a plastic bottle harmful to your health?
Yes, but not as harmful as heating water in a plastic bottle.
Aug 29, 2014 | Refrigerators
Is hydration packs convenient for athletes?
Hydration packs are much more comfortable than bottles of water. You don't have to slow down or stop to reach a bottle. Hydration is speedy, almost effortless tasks; just grab the mouthpiece, take a sip and go.
Sep 06, 2012 | Burton Camping, Backpacking & Hiking
I followed the trouble shooting advice for a Hoover steam vac that has non-spinning brushes. Turbine ordered and replaced. Female receptacle still is not spinning. What now?
There could be several reasons for this. Remember that the brushes will not turn unless the dirty water tank is in place. Also the handle must be released and tipped back. It is also possible that the rubber seal that the lower tank sits on is missing. If you look down into the motor area, there should be a large, round rubber seal that the lower tank sits on. Look for the round tube that protrudes from the bottom of the dirty water tank. This tube sits against the seal. If it is missing it will need replacement.
Jul 11, 2011 | Hoover SteamVac F5914-900 SpinScrub...
American Standard Toilet does not flush except on rare occasions. Most of the time the water just swirls around but doesn't flush out. Waste is left in the toilet but the water does not back up in the bowl...
I would suspect some sort of air lock in the pipe, or just a partial blockage which is slowing the water flow.
You may be able to clear it using a rubber plunger. You need a plunger that has a metal or hard plastic disk fitted above the rubber cup (to prevent the cup turning inside out).
If you have an ordinary plunger without the disk you could probably make one to fit it - perhaps the bottom cut out of a plastic drinks bottle and a hose clip to hold it in place.
You will need to work the plunger quite vigorously up and down in the toilet bowl to force a pulse of water through the system.
Pouring a large bucket full of water down the toilet after plunging may have more impact than just normal flushing. It will also refill the trap.
Feb 25, 2011 | American Standard Colony 2388.012.222...
The computer says bank one is lean and the check engine light is on i replaced the o2 cencor already any ideas
Hello, check for vacuum leaks. THE o2 sensor may not be wrong, however you do need to clear the Code light after making a repair. If you still get the lean code after clearing the computer then you still have a problem.
You can use either a water spray or choke cleaner to detect leaks with the motor running. Get a spray bottle for the water. If you use choke cleaner, get the type for plastics and rubber safe and protect the finish from overspray. With either material, the RPM will change when you find the leak.
If you have the type of Intake that has 2 vacuum- electric solenoids leading to 2 vacuum pods on the intake, some of the electric solenoids would stick and vent air.
I hope my solution is helpful and you can contact our site if you are still having problems.
Jan 29, 2011 | 2005 Ford Focus
Air Conditioner leaking into passenger side of 1999 Ford Escort. Need to locate drain line to clean it out...Found leaves and debris in barrel fan... how to keep keep leaves out... THANKS!
The water leaking is caused by the evaporator drain being stopped up. Look under the car in the area of the firewall on the passenger side and try to find the end of a rubber hose the water is supposed to drain from. Clear it out with air pressure.
The leaves will usually work their way in from the fresh air intake below the wipers. Keep it cleared off to prevent them from getting to the fan.
Jun 05, 2010 | 1999 Ford Escort
Water leak from top drawer. Had F1 flood alarm
Top right corner: it means the bad right actuator could not pull down the lid seal on that side causing a leak. The actuators are sold in pair. They are not expensive. Replace both of them when you order them in. Need to inspect the rubber seal around the top lid since if it is distorted another 60 bucks to get a new lid for replacement also. The new lid comes with the york to engage with the actuators.
May 08, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Water leak
the round opening you are speaking of is known as a "freeze plug" a concave "lid" shaped metal plug inserted in the block to prevent the engine block from cracking during extremely cold weather; any shop can easily replace this plug but, have all of these plugs checked just in case another one is about to go
May 24, 2009 | 1994 Chevrolet Camaro
Resover leaking
The easy fix for leaking under the machine is check to see if the drain is clogged. Open the front and remove the brew unit. You will see a small hole that will drain the excess into the Plastic tray. Usualy I find Coffee grounds clogging the drain hole. Use Pipe Cleaner , Q-Tip to clear the drain hole. you can also wipe out from the other side with paper towel or Q-tips. once the clog is clear. Flush our with water.
Feb 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Thermos BOTTLE INTAK BPA FREE HYDRATI  HP4000GR6 Logo
80 people viewed this question
Top Thermos Baby Care Experts
masud
masud
Tom Chichester
Bill Boyd
Are you a Thermos Baby Care Expert? Answer questions, earn points and help others
