Question about Pioneer PDP-505CMX 50 in. Plasma Television
Can the Pioneer PDP-505CMX be used as a "regular" TV? We just inherited one and I don't see any Antenna In option . . .
  • 4 Answers
SOURCE: pioneer pdp 5080xd
put a pack of smokes direcly in front you wont see the lite anymore
Posted on Dec 14, 2007
donutty
  • 22 Answers
SOURCE: pioneer pdp-v402 40"
http://www.utram.com/medias/Ecrans_Plats/pioneer_PDP-V402_doc_eng.pdf
Posted on Jan 12, 2008
  • 3 Answers
SOURCE: Pioneer PDP-5030HD power supply
click link -ebay shop selling power supply boards for 503hde/pe at 180 pounds you will have to contact him has he does not list them as pioneer are only ment to replace these boards or shops under contract with pioneer i changed mine and only takes min's when you have got the back cover off...
http://stores.ebay.co.uk/Plasma-Parts-UK
hope this helps mark doran
Posted on Mar 17, 2009
  • 4 Answers
SOURCE: Will the Pioneer PDP-R03E Plasma TV Media box work
Yes it will
Posted on Jan 14, 2010
SuperTech-11
  • 1591 Answers
SOURCE: My pioneer plasma tv is
My initial response is "An S-Video Cable"... but I suspect this isn't the information you are seeking.
You don't need to connect your receiver to the TV's video inputs UNLESS you want the receiver to switch between different video devices.
PS - more information on what "my receiver" is would help too, also tell us what you're trying to accomplish as the end result.
tell us about all the equipment you have, and how you would ultimately like to be able to control everything, and what inputs and outputs are on each device.
Posted on Feb 22, 2011
My Plasma will cut on and be perfect for only a few minutes then shuts off. Any ideas on what this could be? Common problems
Most likely the cooling fan is not operating properly. Gets too hot and high temp cutout prevents catastrophic damage.
Apr 06, 2015 | Pioneer PDP-505CMX 50 in. Plasma...
Pioneer pdp-505cmx both red and green lights stay on - no picture - any ideas?
After replacing the power supply board, it is necessary and a must to adjust its Va & Vs voltages. These details will be there on its panel label. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Without adjusting these voltages properly, might make the Plasma Display defective.
Jan 01, 2014 | Pioneer PDP-505CMX 50 in. Plasma...
Cannot decrease vertical size enough using the menu controls. I cannot see the entire picture.
Incompatibility betwen source and tv.Try setting your source right.Set auto on Screen Ratio on either device.
Oct 21, 2013 | Pioneer Pdp-505cmx 50" Plasma Monitor Hd...
Vertical size too large. Cannot adjust enough in menu
Try adjusting the horizontal out first. You may have to do this a little at a time back and forth between the vertical and horizontal.
Oct 21, 2013 | Pioneer PDP-505CMX 50 in. Plasma...
Where do I buy IR Sensor for Pioneer plasma TV PDP-4214. I don't have part number and I live in Alhambra, outside of Los Angeles.
You will only be able to buy the entire board from Pioneer in Long Beach, if it's still available. If not, I may be able to repair the board to the component level. If you need a repair, please contact me through my website at audioserviceclinic.com. I used to work for Pioneer,
Mar 18, 2013 | Pioneer Pdp-4214hd Tv Main Analog Board...
Trying to set up Pioneer 5080 HD for use with NO CABLE. Digital amplified indoor antenna? I don't have the owners manual or the remote.
good luck as almost impossible without the remote to do much with this set, the manual you might be able to google.
Sep 03, 2012 | Pioneer PDP-5080HD 50 in. Plasma HDTV
How can I connect a coaxial cable to Pioneer PDP-505CMX 50 in. Plasma Television
If it has a coax fitting on the back connect there. If it does not have (means it is a monitor with no tuner) connect with a/v jacks to the correct input (component?) from a box and select that input to use for watching programs----picture will always be better via rear inputs than coax.
If you have questions press the make a comment button here.
Mar 25, 2012 | Pioneer PDP-505CMX 50 in. Plasma...
Will not come out of standby
The reported problem is either:
A) your input signal is not being received (or is too weak), so the TV remains in standby mode...check the antenna or SAT or cable connection AND be sure the selection on the remote matches the intended input
OR
B) the TV Guide feature is unable to connect to the update correctly....power down the set (unplug if necessary) for 10- 15 minutes, power on and enter 0-0-0-0-0 as the zip code for the TV Guide...
Nov 05, 2008 | Pioneer PDP-505CMX 50 in. Plasma...
Pioneer pdp 5080xd
Dec 14, 2007 | Pioneer PDP-505CMX 50 in. Plasma...
Keeps switching off
Theres an power supply upgrade that Pioneer extended on most of their plasma models, even after your warranty is up. Contact them it cant hurt to try
Nov 17, 2007 | Pioneer PDP-505CMX 50 in. Plasma...
Pioneer PDP-505CMX 50 in. Plasma Television Logo
81 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
