Question about DeLonghi Ovens
Delonghi Cooker ESS602 Professional. Can anyone help me? Grill element blew. I replaced. Grill element now only gets to a low heat (very dull red). The new element is ok - if I connect to the top oven circuit it gets fully hot. I guess that something else was damaged when the grill element blew but not sure what. Possibly the reostat (if that's what it's called!) which is controlled by the grill temperature control knob. Any idas much appreciated Cheers - Richard
  • 833 Answers
SOURCE: DeLonghi doubleoven electric cooker ESS602
It is hard to know exactly from here. I'd suspect the heater element is open before anything else. If you can get to the terminals of the element itself (unit unplugged!, element disconnected on at least one side), then test for resistance with an ohm meter...available at any electronics shop or large retailer like Radio Shack, Sears Hardware or the Depot.
If there is none, the element is bad...hint: defective elements often have an area on them that is discolored differently from other parts. Food particles, particularly grease splash, will cause burnout. Terminals or connectors that are loose or corroded will cause non-function or failure. Look for those issues. Make sure all connections are tight when you're finished.
Posted on Jun 16, 2008
grandadfixer
  • 99 Answers
SOURCE: Beko DCC4521w cooker grill element
it is done from the rear and inside cavity.Can be supplied approx £24.00+p&p,Check old element for continuity.
Posted on Oct 11, 2008
  • 18 Answers
SOURCE: Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Posted on Jan 23, 2009
protek480
  • 1723 Answers
SOURCE: Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 03, 2009
Testimonial: "very useful thanks"
FixinFax
  • 3085 Answers
SOURCE: oven door open or shut when using grill?
Leave the door open in the broiler position, about 4 inches.
Posted on Jan 06, 2010
Blows mains fuse
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
Smeg oven UK80MFX1 troubleshooting
Nov 30, 2011 | Smeg Ovens
Heating elements in fan oven not working
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Nov 26, 2011 | Smeg Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Oct 27, 2011 | Ovens
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
I have a delonghi oven. The grill element smokes violently as the element heats up. Does it need a replacement grill element?
no you dont need a new grill its just collecting fats from when you roasting and burning off when you initially heat the grill. if you use the grill more often it wont build up as much. covering the roast can reduce the saturation and perhaps a slightly lower temp will help reduce splattering.
Aug 02, 2010 | Ovens
Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
May 14, 2010 | Zanussi ZDQ495 Electric Double Oven
Jun 10, 2008 | Ovens
Ovens Logo
62 people viewed this question
Top DeLonghi Ovens Experts
Naftali Haskell
Level 1 Expert
Mike Teter
Jon Lamb
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
