Question about Cobra 29 LTD CB Radio
I just purchased a Cobra 29 LTD Classic CB radio with a Wilson Little Wil antenna. Do you know of a place in Nashville, TN where I can get my antenna tuned to maximize performance?
  • 391 Answers
Hi im sure there is a radio store somewhere in nashville or try some of your friends on the radio that can do this for you ,all you need is a swr metre fairly cheap and easy to use goodluck
Posted on Mar 20, 2011
  • Steve Tompkins
    Steve Tompkins Apr 01, 2011
    The Wilson should be factory tuned already to 1.1 to 2.1 Swr. Its just a mobile not much help can it get. Buy a Radio Shack SWR meter for $20 + a 6" inch jumper cable to test it. I find most antennas, Magnet mount are already set to good 1.5 Swr reads.
I have had a Cobre 29 LTD Classic, a 29 NW LTD Classic and now a 29 LTD Chrome.It seems that the first two died because of possible bad antenna connections. I was able to calibrate the radios and adjust...
I see two possible problems. First, with a magnetic antenna it is difficult to get the proper ground for the antenna. Make sure the magnetic base is clean as well as where you place it. Second, try running your power lead DIRECTLY to the battery and not using the cigarette lighter. Hope it helps.
Tom
Feb 27, 2013 | Cobra 29 LTD CB Radio
HELLO STAN FIRST HAS THE RADIO BEEN PEAKED AND TUNED? SECOND IS THE INTERIOR LIGHT IN YOUR PICK UP RIGHT BELOW YOUR ANTENNA,IF SO YOU HAVE A PROBLEM BUT EASY FIX THE WIRING GOING TO THE LIGHT ACTS LIKE AN EXTRA ANTENNA CAUSING YOUR ANTENNA TO RESONATE TO YOUR RADIO CAUSING THE A W I LIGHT TO COME ON MOVE YOU ANTENNA BACK A LITTLE FUTHER AND SHOULD BE GOODif you want to get a bettter antenna get a willson 500 mag mount far better
Whats the best antenna and location on an f250 ford p/u ext cab superduty
Something like either a Wilson 1000 or 5000 magnetic mount on the roof--coil and whip unit detach as needed.
Apr 12, 2012 | Cobra 29 LTD CB Radio
I have a cobra 29 ltd classic I install it run the antenna cable and install a wilson 2000 and my swr is to high plus I get the red light indicating antenna once I press the mic . what can I do to fix that
Hi 20008,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
You need to have your SWR checked. You can get it checked at
any cb shack or Radio Shack for free. Sounds like you have everything
else in place. Let me know if you need further help.
Hope you find this solution helpful.
Thanks for choosing FixYa.
John
Jan 28, 2011 | Cobra Radio Communications
Calibrate LTD 29Cobra classic
The misconception is that you can calibrate a radio. You do not calibrate the radio. You tune the antenna. The calibrate knob on the radio is to calibrate the meter in it so you can check the SWR.
This article will tell you everything you need to know.
Nov 04, 2009 | Cobra 29 LTD CB Radio
Calibration problem
Changing the length of the mast more then likely made your antenna to short, and therefore impossible to tune.
Jul 01, 2009 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Dec 20, 2008 | Cobra 29 LTD CB Radio
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Dec 05, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic Operations Manual
For the operation manual, go to cobraelec.com or:
http://cobra.com/downloads/manuals/29LTDCLA.PDF
Thanks!
Dodgem
http://dodgem250.angelfire.com
May 05, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
229 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
