Question about Microwave Ovens
I have a Kenmore Elite dish washer Model 665 76975K602 and the dishes on the top rack are not cleaning properly. There is a very gritty feel on the dishes. Also, I have to rinse all dishes thoroughly before placing them in the dishwasher as they will not clean properly. The manual explicitly states that I shouldn't pre-rinse. What is the problem? thank you. elite_builders@yahoo.ca
  • elite_builde Mar 20, 2011
    This dishwasher is three years old and this only started about 2 months ago. We use only liquid soap and soap packets.
  • elite_builde Mar 21, 2011
    The dish washer is 3 years old and all we use is liquid soap and soap packets, this only became a issue about 2 months ago.
  • 2,069 Answers
That is very possible and you are not the first one encountering such. many sites have tackled this specific problems some with videos on how to troubleshoot and solve it. i'm going to give you two links that will assit you as the steps are lenghty to put here. Link1 and video link 2.
hope that helps
Posted on Mar 21, 2011
    Genius:
  • 1,400 Answers
Hello
Ive yet to see a dishwasher you do not have to pre rinse the dishes.The gritty feeling could be your soap.Maybe a liquid soap would be better os a soap packet.Stay away from powder.
Also if this is a high efficiency dish washer try using saop marked H E or high efficiency.
If the top rack is not getting clean its usally beacauce something big is in the bottom blocking the water from sprayimg up.
Just some ideas.
Posted on Mar 20, 2011
How can I keep the turntable from revolving when using a dish that is too large to turn?
Try removing the M/W turntable and placing a shallow bowl upside down centered over the rotating device. Then place your plate on top of the bottom of the bowl. The device will still rotate but will not be in contact with anything.
Nov 21, 2015 | Kenmore Elite Black 1.5 Cu. Ft. Convection...
KENMORE ELITE #86013 Microwave/Convection Oven:Manual says always use Metal Rack when convection cooking.How can you cook whole chicken or roast? If you put food on top of the rack it will rub against
Yeah, that's an interesting dilema. You need to lift the food off the tray to get proper air circulation, but I've seen those racks and I understand that you don't have enough room to put a full bird in there! Is that by design, or an oversight? I don't know! And what can you do about that? Maybe you can cut off an inch off the support legs of the metal rack....
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 20, 2014 | Microwave Ovens
It is an older model maching and it seems to be clogged and not cleaning the dishes..how do you unclog it
It would be helpful to know exactly what machine you have, but the bottom line is, you need to access the screen at the bottom of the machine, where the water exits into the pump. Many units have a macerator blade in front of the screen that chops up large particles of food so that they will pass through the screen. The blade is attached to the same shaft as the pump, which both supplies the high pressure water to wash dishes and pumps out the dirty water at the end of the cycle, and if there are small hard particles, such as bits of bone, plastic or broken glass in there, they can jam the blade so that the pump does not pump properly. You will need to remove the dish racks whatever covers, etc., are on the bottom inside the machine to get at the screen and/or macerator.
Mar 18, 2011 | Microwave Ovens
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    Dishes are not getting clean particularly in the upper rack. The soap dispenser opens properly but the soap was still there. The washer seems to fill properly and it sounds normal. The dishwasher goes...
    Make and model?Is the water hot enough? Is this a new problem? Is all of the detergent still in the dispenser or do you use detergent both in the washer and the dispenser? Please reply to this inquiry for more help. Do you have the manual?
    Jan 07, 2011 | Microwave Ovens
    Washer is making loud noise while running. It is also not cleaning the dishes very well. any ideas? Thanks
    When my wife started complaining about her dishwasher not getting the top rackclean this is what I found and I wrote a tip about it...
    Dishwasher Spray Arms not Spinning
    heatman101
    Sep 18, 2010 | Microwave Ovens
    Kenmore "Elite" Microwave Gliding Tray jumps Off Track
    Thanks for your input - be sure to relay these messages to Sears.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Sep 19, 2009 | Kenmore 80809 Microwave Oven
    The glass dish that goes around - makes a strange noise
    The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
    You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
    You may have a bad motor orplastic coupler.
    You can usually find exploded views and order parts by entering your model number at the Sears parts site.
    Nov 22, 2008 | Kenmore Microwave Ovens
    Microwave Ovens Logo
    50 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
