Hi there cant get my convergence to adjust up and down any suggestions
    President:
  • 1,779 Answers
Convergence Ic's need replaced.
Posted on Mar 20, 2011
Adjusthow do I adjust the convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jul 03, 2010 | Televison & Video
Toshiba TN61x81-- after convergence IC's replced
Please don't be offended by my suggestions if you are experienced at circuit repair.
You may have a cold solder joint or bridged joint. Check and re-check your connectors for placement. It is normal to have to adjust the convergence and focus after replacing the IC's. There should be a row of focus knobs (ususally covered by a piece of black tape) with the screen controls.
The convergence IC's won't affect the visibility of a color only the alignment.
Sep 21, 2009 | Toshiba TN61X81 61" Rear Projection...
Cant get icns lined up can adjust side to side but
if this is a rear projection crt type set go into the customer menu and select CONVERGENCE--if either blue or red will not move up and down--you have a bad convergence IC---most sets use two of them.
Aug 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Akai
  • Screen looks 3D
Mar 31, 2009 | Akai PT4298HD Rear Projection Television
Toshiba projection tv three colors
  • Screen looks 3D
Mar 23, 2009 | Toshiba 55H70 55" Rear Projection...
Convergence on jvc av-56wp30
  • Screen looks 3D
Jan 27, 2009 | JVC AV-56WP30 56" Rear Projection...
Convergence
  • Screen looks 3D
Oct 09, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Convergence adjustment for red and blue
Press the MENU/SELECT button
on the remote control to show the
on-screen menu.
Press the CURSOR RING
RIGHT
to enter the PICTURE menu.
DOWN
repeatedly until CONVERGENCE
is selected.
RIGHT
to enter the CONVERGENCE
menu.
RIGHT
to enter CONVERGE RED
mode.
LEFT, RIGHT, UP, or DOWN
to
adjust the cross image until the color
outline around it is gone.
Press the STATUS/EXIT button
to exit the menu from the screen.
Aug 21, 2008 | Philips 60P8341 60" Rear Projection...
Sony model # kp53v90 rear projection tv
HI THERE,I HAVE 3 PICS. 1 IN BLUE,1 IN GREEN, 1 IN RED,I
USED THE FOUCUS FUNCTION IN THE MENU, BUT THAT DID NOT FIX THE PROBLEM.ANY SUGGESTION. THNX ALL.
Mar 15, 2008 | Sony KP-53V90 53" Rear Projection...
Red convergence will only move up or down
Stk392-110 red convergence IC is bad...normal procedure===
1) pull chassis   2) replace both Stk's for reliable repair
3)re-assemble  4) re-align convergence
If you hire a technician, 400.00 is ave. price.
Oct 16, 2007 | Toshiba 50H72 50" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
