Question about Garden
Is there a reset button on the Toro Rake and Vac Blower/Vacuum Model No. 51574? It just stopped running.
SOURCE: I have a 51592 Rake and Vac Toro blower.
I had the same problem - then the motor went shortly afterwards. time to by a new one - frustrating because I've only had it for a couple of years.
Posted on Dec 14, 2009
SOURCE: Toro Rake and Vac model #51573
I was able to find PDFs of manuals from the manufacturer directly at this site: https://homeownersolutions.toro.com
Just run a search based on your model. In this case, simply type in 51573 in their search box. You get access to an online interactive manual and also makes PDF available.
Posted on Nov 25, 2008
  • 66 Answers
SOURCE: Toro Super Blower Vac will turn come on. Is there a reset button?
Yes there is. Unplug the unit, pull the plastic adapter that converts it between vac and blower off and you'll see the little square reset button. It is recessed into the case. Push it in until it clicks, replace the adapter and plug it in and go. Good luck!
Posted on Jun 19, 2009
#1 Taper
  • 1041 Answers
SOURCE: Toro leaf blower has spark but will not start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
Just let me know if you need further assistance.
Jim
Posted on Jun 21, 2009
SOURCE: #51574 Toro Rake&Vac--Lost manual
You should have another door that goes in front of the impeller (blade) which doesn't have a vacuum attachment. You should first detach the vacuum door from the bottom, put on the blower tube, and install the other door that came with the blower. Hope that helps.
Posted on Jul 20, 2009
My toro blower will start but sucton not blowing the leaves where is the switch located
Remove the vacuum part and install the protection grid over the intake propeller. This protects you from getting caught in the propeller and engages the safety switch witch allows you to use it as a blower.
Dec 18, 2014 | Toro Garden
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jun 28, 2014 | Toro 51599 Electric Blower 12 Amp
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Motor was losing power and burning
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
Nov 30, 2008 | Toro Blowers Rake and Vac - Electric...
Oct 14, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
