Question about Vizio 42 in. LCD TV
My vizio is now making a annoying buzzing sound coming from the back of the flatscreen...and the tint of the picture is darker...what might this be?
    President:
  • Vizio Master
  • 1,779 Answers
Power supply is straining. Check for bulging caps on the power supply board. The AC cord will lead you to that board.
Posted on Mar 20, 2011
Fumes smell
Your Vizio TV is slowly but surely getting cooked. Whether to repair or replace is a decison you will have to make.
Jan 20, 2014 | Vizio Televison & Video
My 47" Vizio is darker on the left side. Used to be I would turn it on and once the TV was warmed up the picture would be perfect. Then one day it just stayed darker on the left. Everything else works
More than likely you have a bad LCD panel tab. The only true fix is the replace the panel. There are companies who will repair the tab but the cost of repairing the tab, and replacing the panel will exceed the cost of a new TV set. There are youtube videos of fixes but you will have to take the entire set apart.
Apr 08, 2013 | Vizio VO47L 47 in. LCD TV
TV making loud buzzing sound
More sets than you might imagine have this kind of problem---I a regular TV it is usually a transformer that is vibrating hard enough to make the sound---the higher pitched sound is just that--a sound.
If this is a direct view(means not a flatscreen and has a Glass Picture tube it will be either the high voltage transformer or one of several smaller transformers.
This can usually be fixed---seen a few so loud the cats in the house run away.
Let me know model number of set for more information.
On chance it has the high voltage transformer I attach a photo of what that looks like.
May 23, 2012 | Zenith Televison & Video
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
Vizio GV42l buzzing
Vizio makes an ok LCD, but if you notice they no longer make plasma. they stopped last year. Anyways. the buzzing sound is semi serious, it sounds as though you have a capacitor leaking. It is best to get it fixed before it goes out all the way, with it buzzing it will be easier to identify. Best of luck
Sep 12, 2009 | Vizio GV42L 42 in. LCD Television
37inch Vizio TV making buzzing sound from back
my tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Jan 03, 2009 | Vizio L37 Television
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
Vizio flat screen has very red tint when using HDTV component cables
Ummm... i have the same problem and its EVERY type of cable that causes the red tint. its the tv itself. replacing all the darker colors with red. explain that?
Jun 11, 2008 | Televison & Video
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
235 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
