Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Mcculloch gas chang saw 12-35657 model 600088 u the saw runs great but the chang will not move.
  • McCulloch Master
  • 2,239 Answers
Souds like the chaon brake is on, pull the hand guard fully back to the top handle, it should click, now the brake is off, try the saw again.
Posted on Mar 20, 2011
Oil,gas mixture for a McCulloch 610 chain saw
Always use good quaility two stroke oil designed for use in chainsaws ( not out board motors ) and mix at 40-1, oil quaility has moved on greatly so it is acceptable to use less oil than was once needed.
Nov 10, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is gas/0il mixture for mcculloch 2.1ci eager ****** model 60013203
Good quaility two stroke oil designed for chainsaws ( not out boards ) and designed to run at 50-1
May 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
After replacing the fuel lines on a mac3200 gas is running out of the bottom of the saw, after the tank emptys the fuel quits leaking. the saw runs great though
This is usually because you used a fuel line that is too small to seal the holes they pass through in the fuel tank. When they pass through the holes in the tank they should be very tight so gas cannot leak past the lines.
Jan 31, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a McCulloch MS1636NAV chain saw. The engine starts with the choke pulled out. When I push the choke in the saw dies. I've changed the spark plug, replaced the air filter. changed the gas, 40:1.
Its either sucking air in throgh a loose connection in the fuel line or the carb is stopped up. Take it apart very easy so you don't rip any gaskets, and clean evertthing with a can of compressed air blow all the tubes out real good. You may have to get a carb kit it that does not work.
But that sounds like what it is, running out of gas when you let more air to it.
Oct 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel mix
Quick check with mfg (DAGS mcculloch) yields: 40:1 with their 2-stroke oil and 87 octane.
I've run one (with 14" bar) for years on same 50:1 mix I use in other saws with no problems- synthetic oil and regular gas. One of these saws is now 30 yrs.old. And ... no smoke-cloud, nor port/muffler mung.
With new saw, you might want to use more oil for first few hours. Just remember that doing so leans the fuel mixture.
Aug 02, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need to view gas line hook up. On mac3515 chainsaw
No 3515(35cc,15"bar)s a 3516 is provided.
A McCulloch Mac 3516 model model 21-600035-59. (may not be your saw):
http://www.ordertree.com/modelinfo/MCC/21-600035-59-Mac-3516-IPL-211318-01/139.21-600035-59-Mac-3516-IPL-211318-01.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
If the above is not your saw, yours can be located here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
A typical fuel system and a couple of tips follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If properly plumbed your saw will run with the carburetor to primer hose capped off.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 14, 2010 | McCulloch 10" Electric Pole / Chain Saw
I have a McCulloch MAC 110, Model 600016C which
The IPL (exploded parts list) for your saw can be found here:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/McCulloch_Gas_Chain_Saws_Parts_Manuals_11_600016C_MAC_110_01_77_to_02_83_IPL_95807_R2.pdf
Page 6 item 21.
You have to remove the engine to access it.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
There is some discussion about the proceedure in the McCulloch thread. Its a good little saw. I'm awaiting oiler parts on mine. HTH
Lou
Oct 03, 2009 | Garden
McCulloch 14" electric-will NOT run
check the carbon brushes in it. open the cover of motor you can see two pc. of carbon touching the armature. If that become short it need replacement
Jun 29, 2009 | Garden
Mcculloch chainsaw 2416
All you have to do is call 1-800-521-8559 and select U.S. then select the parts department, have your model number ready and ask them for a PDF of the owners user manual to be emailed to you, they will normally be sent in 1 hour for free.
Aug 03, 2008 | McCulloch MC1275 Steam Vacuum
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
102 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
