Question about Speed Queen AGS17AWF Gas Dryer
There is a buzzing sound when I attempt to start my dryer
  • Speed Queen Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 20, 2011
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Dryer won't start.. has power sounds like something binding. long buzzing sound when starter depressed. try once or twice and then nothing for a while. come back try again ..long buzzing sound again
Hi and welcome to FixYa, I am Kelly.
You did not include a make and model number for your dryer so... this is a GENERIC response. With a make and model number we can better help you.
The long buzzing your hearing is the motor winding trying to start the motor. After 30 - 45 seconds if the motor does not start the thermal overload will cycle and prevent further attempts for around 5 - 6 minutes until the motor winding cools down.
Causes of a dryer motor not starting:
1. Binding.
a. Broken dryer fan blade lodged inside the blower housing
b. Motor start switch failure
c. Motor bearing failure
2. Dryer drum bearing / roller problems
a. The drum can be bound up and dragging on internal components of the dryer
b. The Idler pulley bearing may have failed and it is now a brake.
c. Front or rear drum seals failed / pinched against rear or front of the chassis
d. Drum roller bearing failure and is now a brake.
Reach inside the drum and see if you can turn the drum. If you can not turn it with a little effort, you need to find out where the binding is inside your dryer.
This is the best I can do for the moment without a model number. With a Make and Model number I can provide parts listings and item numbers of where to check.
Thanks for choosing FixYa.
Kelly
Feb 06, 2011 | Dryers
Buzzing noise from dryer and wont start
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 12, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
The timer makes a loud buzz sound and the dryer will not start
It sounds like your motor has gone bad....it will buzz really bad when it is tring to start and cannot...
heatman101
Apr 09, 2010 | Maytag PYE2300AY Electric Dryer
Kenmore model 66812694 - quits running, buzzing noise at restart
bad motor,when you hear that noise open the door,hold in the door switch with one hand and with the other spin the drum and have someone else start it while you do this,all your doing is helping the motor start to spin but it sounds like a bad motor,this could be from not cleaning out the dryer,if it's gas it should be done once a year,electric can go another 6 months because there isn't an open flame in there,if you clean out the dryer and vent line the clothes will dry on time,the parts will last longer and you won't have a dryer fire.
Nov 19, 2017 | Kenmore Dryers
Dryer will not work. Makes buzzing sound when
locked up dryer motor,replace-mike
Jul 17, 2009 | Dryers
Kenmore gas dryer buzzes but does not run
sounds like the start windings in the motor have gone bad. The only way to fix this is to replace the motor.
Feb 04, 2009 | Kenmore 73932 Gas Dryer
Dryer wont start
open door and spin drum to left then right.
Oct 02, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not start
Hello jslovik,
Welcome
You said, When you turn the knob a buzzing sound starts but that's it. The Buzzing continues as long as the start button is turned. Dryer is only 2 years old. Any help is very appreciated.
It sounds like the starting switch is bad!
10 134398300 Switch,start ,turn type In-Stock $ 11.29It appears in the diagram at the page below in diagram # 10
http://www.pcappliancerepair.com/model-display.php
If you do not know to diagnose this or repair it, please call an authorized tech.
Let me know what you do and how it goes for you?
Huuum
Believed I solved your question.Happy to have been of assistance.
Please remember to leave a rating.
Sep 19, 2008 | Frigidaire FGQ332ES Gas Dryer
Speed Queen AGS17AWF Gas Dryer Logo
253 people viewed this question
Top Speed Queen Dryers Experts
Tim Whalen
danoyachtcap
danoyachtcap
Marvin
Marvin
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
