Sony tv problem
I have a sony 27 inch tv that is 12 years old. When we got back from vacation I noticed horizontal lines in the picture. If I lean it forward or bang on it the picture returns to normal. After awhile though the lines return and I have to bang on the tv or lean forward to correct the picture. I did have a few instances where I turned the tv on with no picture present. If i move the tv a little bit, after awhile the picture comes back. I am about to get a new tv, but will get it fixed if it is a small problem. Thanks.
    Sergeant:
  • 308 Answers
You have a loose solder connection or two. If I knew the model number of the set, I could be more specific. I would expect the repair would run about a hundred dollars, so make sure the picture quality is great before going to the expense.
Posted on Aug 03, 2008
Horizontal lines on SONY TV
the ribbon flat connection tapes that connect the led panel driver to the panel have prob delaminated
this cant be repaired easily and you would need to replace the panel
Dec 05, 2014 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each color...one is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
No picture appears on screen
without seeing the set this is a hard one to fix if the button is slack when you press it then the button is going to be the problem otherwise it could be a transformer that has gone in the set, 12 years is a good age for a tv so i would suggest replacing it with a new lcd or plasma.
Mar 08, 2009 | Sony FD Trinitron WEGA KV-27FS320 27" TV
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Sony KV-27S10
is it vertical problem or retrace lines can you tell
Aug 06, 2008 | Sony KV-27S10 27" TV
A horizontal line on sony 32'' LCD
This is a known defect with the lcd panel.With a little persistence to the customer support with sony they will fix the problem for free.
Apr 24, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Horizontal line (with about an inch of picture)
check a capacitor on the horizontal section
Oct 28, 2007 | Toshiba 27AF43 27" TV
Picture deterioration
Your whole problem my freind is dryed up capacitors. You should go, if you have the technical ability to replace these capacitors, to http://servicemanuals.net, download the schematic diagram, and start replacing the waveshaper capacitors in the vertical drive circuit.
Sep 23, 2006 | Sony KV-35V35 TV
Black vertical line on right side (intermitant)
Your problem sounds like the stk type regulator.. Itsnot a really expensive part BUT on a set this old yes you can repair it but also your gonna be repairing it more and more as the capacitors are drying up and the circuit is getting brittle. I wouldnt invest anything in this set. time to make a boat anchor out of it!
May 24, 2006 | Sony KV-27S46 27" TV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
