The blue screen is just there it wont go to the menu
  • 731 Answers
Hi :) When you first start windows just before you see the windows logo hold the F8 key down for a second or two when the list comes up pick VGA MODE and continue and see if that help maybe you have to change the video drivers back or have corrupt drivers you can also try SAFE MODE.
Posted on Mar 20, 2011
  • 961 Answers
If you have done any updates or changed anythng recently,ie;change of cables, resoltion etc. Try a shut down using power button on tower and unplug. Plug back in and start in safe mode. Click "start" find "control panel", click on that to open. Find "device Manager", right click on that and open. Click on the box with + next to dispaly adaptors. You will get a drop down of you devices. Right click on the one you use and you should see "disable", if you see "enable" click on that. Click on the box with+ next to monitor. You should see a drop down ith your monitors.Right click on the one you want and, again you should see "disable" if you see "enable" click n that and exit. If either of those two things showed enable when you checked them and you enabled them you probably fixed your problem. Now restart your system normally. If it doesn't come back, shut down at front of computer and restart in "safe mode" again wait for widow to come up about system restore, now this is only if you have made recent changes o updates, Click on what is system restore and another window will come up. Read down until you see "start system restore" and click on it. This will take a couple of minutes. A window will come up and click on start restore. Your computer will perform restore and restart on it's own. After it restarts, give it a couple of minutes tillyou see a window with "system restore complete".
I have 42" led proscan flat screen hdtv that i turned on today and the screen was blue, it wont show menu or nothing just blue
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 16, 2015 | Proscan Televison & Video
LG 37LG30 wont come on. Gives blue light, but screen stays black and no sound
Sounds like the problem could be in the power supply of the TV. Have a technican check for defective capacitors if you're not equipped to do the job yourself.
Apr 22, 2013 | LG 37LG30 37 in. LCD HDTV
Wd-73737 wont turn on blinking green light
First is if you are able to get it to turn on and blue screen only appears it will shut down as no signal noted.
If you can get it on with Mitsubishi remote : Menu, 1,2,3 enter
This is the soft reset and the set also has a hard reset.
Try the soft reset first and let me know what happens.
Mar 09, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I have a black menu box on my screen and it wont go away.
go to your menu and remove the text option. if not go to menu screen and change to blue or black or none.
Feb 01, 2011 | Toshiba Televison & Video
My acer X193w screen went blue and wont show red
I once had that problem, I think you need to make sure that the power supply cable is fitted well and your monitor receives enough power. if its shares the power cable with your CPU try and separate it then restart your computer.
Jun 24, 2009 | Acer X193W LCD Monitor
Convergence problem Mitsubishi 6043
DOES IT AUTOMATIC CONVERGENCE,,TRY THAT,,IN THE MENU,,TRY NEW JACKS
Mar 27, 2009 | Samsung HC-P4752W 47" Rear Projection...
Blue menu screen stays on
Hi! the blue menu screen can be turned off by pressing the same button that caused it to appear. In most cases pressing the "Menu" button on the remote or TV-control will make the blue menu screen disappear..
I hope this helps!
Mar 10, 2009 | Zenith C27A24T 27" TV
Blue ipod nano4gb wont turn on
Try reseting your ipod. Hold down the center button and the menu button simoltaniously.
Jan 22, 2008 | Apple iPod nano
Connection screen
Reset the player - manual has instructions
Remote possibility:
Use the Thumbwheel to rate the song (1 to 5 stars) then press
|<< button to return to Music Options menu. My Top Rated
Songs can be viewed in MUSIC menu.
Dec 26, 2007 | SanDisk Sansa e260 MP3 Player
Watch tv through antenna
mine turns itself on as soon as its plugged in,goes to just a blue screen and buttons do nothing,no menu,no volume,just a bright blue screen,whats up with that?
Sep 23, 2007 | Maxent MX-42VM 42 in. Plasma HDTV
Computers & Internet Logo
David Payne
David Payne
