Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Flashing Red Led on Amana PTH123A50AB
How do I find and fix Red Flashing Red LED on Amana PTH123A50AB?
Any help would be great help.
Thank you,
maxgandhi@gmail.com
    Problem Solver:
  • 6 Answers
I can help with this call 1-888-855-9987
Posted on Sep 09, 2008
Apc smart ups 2200 all led flashing 3 orange 2 red 1green,what is that? and How to Fix It?
this problem is caused control board with that. the solution is replacement.
Jul 21, 2014 | APC Smart-UPS 2200VA LCD 230V...
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Hi! GREAT site! We have a Sony SXRD KDS-R60XBR1 Projection TV and it stopped working last night... We are getting FIVE red blinks! What does that mean? Fans, bulbs.... ??? Thank you in advance for any...
5 blinks if for the ballast that powers the light. You can try changing the bulb first, if that doesn't fix it then I believ it will be your ballast. If you haven't changed the bulb before It could probably use one anyway, and you could keep the old for a spare.
Here are some more from sony on this.
According to Sony:
Red LED Flashing four(4) times
o Fan not plugged in
o Foreign object hitting blades
o CN2301 on ASU board not seated or connected
o ASU shield touching S1 board
Red LED Flashing five(5) times
o Interconnect harness from Lamp driver 5-pin to ASU 9-pin board not connected
o Lamp driver failure
o Bent pin on Lamp driver 5-pin connector
o DSU to C board harness not locked
o CN6501 on G board not seated or connected
o Lamp failure
Jan 29, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
KDS-60A3000 new bulb gets 6 flashes of red led
Please put back lamp (bulb) cover properly and check as lamp cover is open/ not fixed or improper fix is also cause of LED flashing.
Jan 08, 2009 | Sony KDS-60A3000 60" HDTV
Sony Projection Tv Model KP-51HW40
With both of error codes flashing, the problem is trying to figure out wich one to focus on. The flashing 6 code is an indication of HV failure which would then cause a vertical failure(4 blink code). There are so many things that would cause this problem. I can narrow it down to the "D" board to fix your problem. If I were there to troubleshoot it, I could narrow it down further I.E. flyback, HV distribution block. I suggest getting a tech diagnose the exact problem. I wish I could narrow it down better for you. Please take time to rate this solution and if I can be of further assistance, let me know
Dec 13, 2008 | Sony KP-51HW40 51" Rear Projection...
8 flashes, bad IAT
Take the buttons off of your unit and remove the board cover by taking out the 2 screws on each side holding it in.  You will See on the right hand side of the board 4 post specifically , 2 for your indoor thermistor and 2 for your outdoor.  unplug your inddor  from the board ( make sure power is off)   and there should be a plate you can remove on the front of the unit on the right hand side of your evaporator coil , remove this and disconnect your thermistor from the coil (should snap right off )   pick up a new thermistor and just slide it right back in.
Aug 01, 2007 | Amana PTC123B35AE Air Conditioner
IBM CRT Monitor - monitor off, red LED flashing
This monitor is worth $30.00. Trash it. http://www.etech4sale.com/IBM_6549_4AN_G96_19-Inch_White/G96/partinfo-id-119721.html
Jun 25, 2007 | IBM G 96 (White) 19 in.CRT Conventional...
Connection
Thank you SO much , i know this is old, but i recently had mine repaired and i thought i'd have to do it again but you saved me a weeks worth of stress, and renewed my faith in logitech, as if i EVER doubted them <3333
Jun 10, 2007 | Logitech FreePulse Wireless Consumer...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
292 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
