Question about Whirlpool Inglis IP8200 Dryer
Element is too hot (red hot), what is defective, termister or what should I be checking?
  • Whirlpool Master
  • 43,501 Answers
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Posted on Aug 15, 2011
Oven will not turn on after self cleaning has finished
If electric turn the oven to bake and look at the bottom element. If if does not turn red hot, it may be defective.
If gas, turn to bake and watch the igniter to see if it get red hot. If not, it may be defective.
May 22, 2014 | Ovens
Roper range oven
follow this steps and fix it. God bless you
.Bake element
Replace if found defective
1.Broil element
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
2. Infinite switch
Another reason, why the element would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangeoven-repair-help.html#electric#ixzz2ab45pXtc
Jul 30, 2013 | Dryers
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
Sep 28, 2012 | Fisher and Paykel Dryers
My LG Front Load Washer is not getting hot water
Did you mean that there is no hot wash, if so the heater element could be defective or there is no power from the panel to switch on the heater for the hot wash. Check the resistance of the coil and if open this must be replaced,
check this link; Heater element.
Jul 02, 2012 | LG Washing Machines
My oven does not start
Hello there:
It doesn't work at all dot_lineone.gif 1. No power
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter. Sometimes the power cord disconnects or burns at the appliance, if this is the case, the wiring and the terminal block must be repaired or replaced. ^ top clear.gif Top element doesn't work dot_lineone.gif 1. Top element
2. Infinite switch
Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#2-1#ixzz1CZ54wKfT
Jan 30, 2011 | Whirlpool Ovens
Machine runs but there is no heat element or thermostat ?
hi
you will need a mulit-meter for this to check. remove real panel and unplug machine before doing this...check the element , but most of these have a defective thermal fuse...it sits about the heating element on the side of the can..it has two red wires going to it..check the fuse with your meter./or bypass the wires and see if the element gets hot.
May 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Dryer is running fine just not getting hot
It sounds like the thermal fuse or heating element are defective. Both components are easily checked with an ohm meter or multimeter. The fuse is usually inside the back of the dryer by the exhaust duct. Both components should have continuity, if not they need to be replaced. Sure hope this helped.
Jul 20, 2009 | Roper REX4634KQ Electric Dryer
Bottom heating element in oven is not heating up.
Jun 10, 2009 | GE Spectra JBP78 Electric Kitchen Range
Hot Water Heater Trouble
(1)Have the unit check for electric voltage to the element
If voltage going to the element and no heating
(2)Your heating element may be defective.
(3) Have it replace by qualified personel
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Inglis IP8200 Dryer Logo
168 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
