Question about RCA Televison & Video
Will not show any highdef. - RCA Televison & Video
  • 2 more comments
  • djdexchange Mar 20, 2011
    do not proceed if the charge is $10. i authorized a $5.00 charge.
    rca senium srs
    true surround model # HD52W140
    serial # C434C8032
  • djdexchange Mar 23, 2011
    you needed further info
    rca selenium
    hdtv srs true surround
    dtv link
    model: HD52W140 year made :2002
    serial no. C434C8032 chassis :ATC311
    djdexchange
  • djdexchange Mar 28, 2011
    i have not received any response since mar 23 and that was a request for more info. i sent the requested info twice to alpug without any reply.
  • djdexchange Mar 31, 2011
    does anyone actually look at the emails, comments etc that i have sent ?
    you must think that i am an idiot or something that the best advice i get is make sure that i have an hd source and to check all the cables.
    my access key is 46115mdwmpy
    djdexchang
    Guru:
  • 276 Answers
For High Def video, you need a HD source like digital cable on a HD channel (HD service) or a Blu-ray Disc etc. AND you need to be connected from HDTV to the source component using either a HDMI cable or component video cables. Also be sure to select on the TV (using TV remote) the input for the HD source component (cable box).
Posted on Mar 28, 2011
    Genius:
  • 1,622 Answers
Hi,there are many reasons you could be having problems with your LCD TV. The thing to remember is that these things are microprocessor based, just like your computer. That means that at the first sign of trouble you should do the same thing you do with your computer; reboot it! That's right, if your LCD TV is dead ir unresponsive, turn it off with the remote or power button, wait about 10 seconds, then unplug it from the wall. After about 1 minute, plug the power back in and turn the TV on again. With any luck, your TV is now fixed. The next thing that causes problems with all new TVs, not just LCDs is the HDMI connection.
You see, HDMI is a fantastic way to get high definition video, but it's so good that the content providers were worried their stuff would end up out on the Internet in pure form, easy to copy and distribute. To prevent such an occurrence, a copy protection scheme called High Density Copy Protection (HDCP) was developed. This is an electronic data handshake system where the source and display devices have to recognize each other and agree that it's okay to send video. If there is no handshake, or the process gets corrupted in some way, poof, no more video. This problem was extremely prevalent in the early days of HDMI, but has been steadily improving since about the end of 2007 or early 2008.
If you are having problems with your TV, it may actually be an HDMI related issue. Here are some of the problems you might encounter.
Problem 1: No Picture
If you see, or rather don't see this, then shut everything down and then restart the system. Make sure all the connections are in place first. Look at the screen. If you see a resolution notice chances are the DDC line has communicated between source and sink. Good news for you! The problem is likely video related.
Problem 2: Flashes, No Audio, Pink Screen
No audio accompanied by a pink screen is usually indicative of a DDC communication problem. What's that mean for you? To check this, power up the system while all the HDMI cables are connected. If possible, try using shorter cables. Here you need to see if the system works at all. If for some reason the system still fails to come on, try using different inputs. You may find that your cable box will work and your DVD may not or vice versa. This can happen because of stray capacitance on the DDC line inside the HDMI cable. This may actually be caused by the hardware itself. If you think it may be, try getting a DDC line conditioner. Normally, these types of problems completely go away when conditioning is introduced.
Problem 3: Sparkles in the Picture
This is normally a video data transmission problem. Typically data transmission problems with HDMI are cable related. It could be that the cable is underperforming due to its length. This is especially common with cheap cables. Remember the HDMI spec says cable length should not exceed 10 meters. Shortening the cable should improve the signal integrity. Another possibility in this situation is a bad connector. HDMI connectors are notoriously fickle anyway.Try a new cable at each position along the signal path.
Symptom 4: Picture Comes On, Then Goes Off
Typically, this is caused by one of two things. The first is when one or more of the video TMDS channels has a high bit error rate or is not working at all. Next is when the DDC line doesn't quite make it. In that case, the HDCP is not getting a new refresh key. Buy a in a better quality cable with larger wire. When it comes to wire gauge, smaller gauge equals bigger wire diameter. Hence 20 gauge is larger diameter than 24 gauge.
If you're having LCD TV problems, check these things before you call a TV repair company. In many cases you can easily fix the problem yourself without spending a fortune.
Discover what you need to know about getting the best picture from your LCD TV, setting up your home theater the right way, and wowing your friends with your AV knowledge. There are even special, insider only deals on top quality AV and home theater products. To get a peek inside check out the What is the Best LCD TV Guide.
Hope it helped..
Posted on Mar 21, 2011
    President:
  • 1,961 Answers
Hi,please give me the model and make of your TV also please include a brief description of it ex; LCD,DLP,plasma etc.post back!
Posted on Mar 20, 2011
I tried to use my xbox on a different tv than i normally do, and im also using different cords. it does not work. Why?
its outputting the same signal that it was before if it was highdef and the new signal is not than that creates issues i dont use 360 so i am not sure how to do the signal reset but it can be done
Dec 20, 2010 | Microsoft Xbox 360 Console
Lost highdef picture. Gtting regular picture only.
check ur connection cables,,try new cables and diffrent video input,,,and even try a new device to send signal to tv,,you no dvd or bluray,,
Nov 03, 2010 | Mitsubishi WS-65813 65" Rear Projection...
I don"t know where my manul is and the tv switches from tv to dvd what do i do. It is a highdef 1080p please help
Go into the menu and shut off the autoscanning. When it detects a lack of signal (like a dark spot between commercials or a DVD loading up) it confuses it for no signal and thinks it should switch.
Aug 09, 2010 | Mitsubishi WD-65731 65" HDTV
I bought an xbox 360 and the screen is on split mode and its black and white. there is no game in the console. how can i fix it?
Im not positive.. but on the back of the A/V (Audio/Video) cord right on the main plug their is a setting for it to be HighDef or not.. you should use that switch accordingly..
Apr 06, 2010 | Microsoft Xbox 360 Console
Problem attacing cords to wii
You will need to buy HD leads for the Wii. You can pick these up for a cuple of punds on Ebay. Although you will only get the resolution to about 560i.
Dec 05, 2009 | Nintendo Wii Console
How do i set up my grandchilds psp2 to my portable tv?
first off dont think you can with portable tv needs to aleast be highdef tv or HD tv cause the psp need a high porwered tv and the psp also has to be a 3000 model for it to work anyway . and you need a special cable hook up to connect for psp to tv. so make sure the psp has a hd or tube tv with a least the need componets to hook up and the hook up cable.
May 03, 2009 | Sony PlayStation Portable (PSP) Console
COD4 Pc version
it might possibly be the people your playing with online. and if it windows vista i hear the game does not work well.
Mar 22, 2008 | Microsoft Xbox 360 Console
Ps3 games with fuzzy screens
This is most likley from the television not from the game, Playstation 3s are ment to be run in Highdef if you have a standard def television and are using the standard av jack hookups you should probably upgrade this will fix the problem.
Feb 27, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
44 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
