Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Motor make noise in water check propeller look good armature good all speed good motor is 2008 motor guide fw hb 71 lbs 24 volt motor will whine noise in 1 2 3 4 5 speeds
  • 12,061 Answers
Hi, this sounds like a speed controller failure, i suspect the electronics speed controller is/has failed, failing?
The ONLY real way to find out what's wrong is by substituting the speed controller module and see if that fixes things.
To see if the motor actually works, try using it directly across a 12 V Battery, NOT a 24V, and see if you get any movement or even a Kick, if you do get evidence of it working, then to prove further try it on the full 24 V, it should rotate...
Now if it works like that direct, then now hook it back up to the speed controller, and see if it works, if NOT, then we have proved the electronics to be at fault. Replace/Repair the controller. (I always advise replacement, as a repaired device, has a greater chance of a future breakdown within 9 - 18 Months.)
Posted on Mar 21, 2011
I got a 1999 motorguide 67lb brute 767 it is 12 or 24v when i swich it to 12 volt it dont work but when i put it on 24 volt it runs but not like it should i need help
My guess is that the motor has leaked water and requires the 'extra' power of 24V to spin it up. To check for a water leak, first remove the prop.
Here is a schematic to get you started:
http://www.mikesreelrepair.com/schematics/displayimage.php?pid=8362
After the prop is off, you will see 2 or 4 bolt heads. You'll need a 5/16" socket. You'll want to remove only one of the outermost bolts. The bolts are about 8" long but only threaded for an inch or so. When you get it out you will be looking for a black, oily looking residue, whch would indicate water still in the motor unit. If you see rust or a white, powdery substance that would indicate there was water intrusion but has since dried out.
Give everything a good clean, replace all the o-rings, clean up the armature commutator (copper brush contact on the armature) and re-assemble.
Apr 01, 2014 | Electrical Supplies
My motor guide trolling motor died . It was on the new boat that I bought in 2011 . Checked the breaker fuse and it's good, tested the wiring with a volt meter couldn't find anything. Could it be the micro...
do you have it hard wired to pos and neg or does it have the 3 prong plug in switch ..if 3 prong its for a 24/36 volt motor wont work on 12 volt less you have the 12 volt plug
Oct 16, 2013 | Boating
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Bosch dishwasher whining
if you listen to the appliance and the noise is louder on the rhs and low down this is probably the main wash motor they sometimes do whine if you can live with the noise leave it alone if not you basically have to take the whole applianmce apart for access to the motor costly repair would take a trained pro about 90 mins to replace the motor
if the noise is coming from the front of the appliance more to the lhs and is intermittant ie when it first starts up and then about half way through its likely to be the drain pump relitively easy to replace and you dont have to take the appliance to bits just go at from the front
good luck
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Beko DE 2431 FW dishwasher
hi there.....when the machine brings water in...have you cancelled the program reselect a program and checked that it is puming out..if all is ok then you need to check that the main wash pump rotates freely....if all is ok here..then i suspect you have a failed capicator on the wash motor....little white cylinderical component on top of the motor
regards Sir Galahad
Jan 20, 2009 | Beko 24 in. D3421F Free-standing...
Minn kota 65
open up the prop area and look for / remove corrosion
Apr 06, 2008 | Minn Kota 55 PowerDrive Motor/Sonar Combo...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
93 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
