Question about Fisher and Paykel DG08 Electric Dryer
Have a dggx2, unit is taking 3 hours to dry clothes. we cleaned dryer vent, did not solve problem. any help thanks. ldchada@comcast.net
  • 1,531 Answers
have a dggx2, unit is - noavatar_s.gif seth765
Rank: Guru
Rating: 89%, 593 votes
The most common problem for a dryer to take more than one cycle to dry is restricted air flow.
1.when the dryer is running go outside and find where the venting is located, there should be a good amount of air flow.
2. if the air flow is not good look at the ducting coming from the back of the dryer and make sure it is not kinked or pushed back to far.
there is usually lint build up some where along the ducting or at the end of the duct where it vents to the outside.
3. if you have access to a leaf blower,this can be used to help clear any lint build up inside the duct from the dryer to the outside venting.
move your dryer out and take the leaf blower tube and stick it in the hole and turn it on.
the vented louvers need to be removed from the ouside of the house to allow the lint and things in the duct work to be blown out.
Posted on Mar 20, 2011
What is fault code 6 mean?
Hi Darrell, The link below is about how to trouble shoot and fix your dryer.....I hope this helps.....CHEERS..
http://removeandreplace.com/2013/09/21/fix-clothes-dryer-heating-drying-clothing/
The most common causes for an electric or gas dryer to stop drying or heating is:
1. The dryer lint screen (lint trap) has not been cleaned (poor or restricted airflow).
2. A clogged or kinked (bent) dryer air vent hose (inadequate or no airflow).
3. Drum has stopped turning, broken drum drive belt.
4. Overheated or bad motor (possible thermal overload).
5. Thermal fuse or thermostat (could be caused from dryer air vent hose lint buildup)
6. Heating element burnt out.
7. Loose electrical plug or power socket.
8. Other mechanical issue, fault or malfunction.
Mar 31, 2016 | Fisher and Paykel DGGX2 Dryer
Amana ALG443raw gas dryer
sounds like the thermostat is shot..do you fix this sort of thing yourself?
Mar 17, 2008 | Amana ALG443RAW Gas Dryer
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
It takes the dryer 2 hours to dry the clothes. I always make sure lint filter is cleaned after each cycle.
Hello there and thanks for choosing fixya
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Feb 03, 2011 | Dryers
Not heating properly, many cycles to dry loads
Check the following to address this issue--
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Taking to long to dry a load of clothes
Hi, there are a couple possibitlies. Is the 4" vent that goes outside clean or free of a kink in the vent? This unit has a double element, one side of the element might be broke. Check you vent (even the vent flap outside) and let me know please.
Thanks
Vic
May 15, 2009 | General Electric DCVH680EJWW Dryer
I have a neptune drying center and it's taking 3 hours to dry
Check the exhaust duct again. There must be a blockage, a kink, or a disconnected vent pipe.
May 03, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Maytag dryer
Dear sloika,
I do not believe the problem lies within the dryer unit.
when the dryer unit fails to dry clothes in reasonable time 90% of the time it is the clogged air vent is the reason.
Dryer vent cleaning improves the safety and efficiency of your dryer installation. As dryer vents become filled with lint and other debris, drying time increases and can cause the dryer itself to overheat. This increases energy consumption since the dryer has to run longer to dry your clothes and can also cause fires in the dryer or the dryer duct. The Consumer Product Safety Commission reports dryer related home fires are on the increase.
  • First check your vent hose between the back of dryer and the air outlet on the wall. Vaccum clean the dirty hose and even into the dryer unit using flexable vaccum attachment. also try to vaccum clean airoutlet that goes into your wall as far reach into and much as possible. The dryer's lint filter and its path needs to be cleaned as well.
  • If all air flow path are cleaned it will improve 200% of your drying time.
There is also professional dryer vent cleaners in your area who can help solve the problem. just check your yellowpages..
Feb 16, 2008 | Dryers
Cleaned vent hose, dryer still taking forever to dry clothes.
you have a family of squirrels living in the rest of the vent tube which is leading outside...check vent outside. I once had flying squirrels come into my house through the dryer vent! My dog had a kitten.
Jun 04, 2007 | Whirlpool GCEM2990LQ Electric Commercial...
Fisher and Paykel DG08 Electric Dryer Logo
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
