Question about IBM ThinkPad T43 Notebook
My hard drive isn't recognized and I cannot install windows xp operating system. Don't know if I may have a bad motherboard.... the bios is in good condition...
    Master:
  • 451 Answers
Can you see your hard drive when you go into the bios settings?
if you don't then your hard drive may be bad.
you can order a new hard drive from newegg.com
please check if your hard drive is SATA or IDE. I believe it is SATA.
2.5"
Posted on Mar 20, 2011
  • Tony Mar 20, 2011
    sorry didnt see your last sentence.
    you will need to format your hard drive before u can install winxp
Panasonic Toughbook won't load Windows XP CD
You can check to see if the hard drive is dislodged, but other than that I don't know what to tell you. If you know the drive is functioning correctly then your motherboard is probably dead.
Jun 25, 2012 | Panasonic Toughbook CF-30 Notebook
Motherboard for hp pavilion xt963 is there away to tell if its bad
It's very possible that your hard drive is dead. If you get a prompt when booting it such as F1 then the motherboard is working (so far), therefore it means the BIOS is ok and also that your CPU is ok if not nothing will show on your screen. If pressing F1 gives you boot options then select CD. If it won't boot from your CD force it by actually going into BIOS setup and selecting CD as primary boot drive then press F10 to save. (if BIOS setup options don't show when booting try pressing F10 or F8 and any other function keys after F1.
Make sure you have the installation disk. If the PC still doesn't boot or detect it you should try another CD/DVD drive, yours might be bad or buy or borrow a DVD/USB external drive and select it as boot drive in BIOS. Often I've seen that when booting if either the hard drive is bad or your operating system is corrupted it will prompt F1 because it cannot detect either. If OS is corrupted you will be unable to get to safe mode especially if the hard drive is bad, the recovery partition is on that hard drive and safe mode is a Windows program not BIOS.
After you've tried connecting a different CD drive to install your OS you should be able to at least see the Windows installation or whatever operating system you use asking to begin installing. If the installation fails then we move on to the hard drive; take it out and put a new one then try again.
If none of these help then there might be a circuit shorted out on the motherboard which can cause some things to work but not others although this is rare. Lastly I don't know what you meant by USB in your question because unless you have a bootable USB drive the system isn't going to do anything with it anyway.
By the way someone here mentioned RAM memory. BIOS should still show even if your memory is gone but some systems are quirky so this needs to be tested as well. I could go further if you had posted your system's specifications such as how many sticks of RAM you're using. Try dusting off your the inside of your computer with compressed air. Dust acumulation tends to cause weird behavior on a computer.
May 14, 2012 | Intel Motherboard
On start up my lg x120, (s/n: 003msfb0044355)" displays operating system not found" it wont go any further.What do i need to do?
This type of message indicates that the BIOS is unable to detect an operating system. What may cause this condition can be a loose hard drive, a bad data cable, bad hard drive, bad motherboard storage controller, malware, virus, or incorrect BIOS setting.
To troubleshoot, start by entering the BIOS and see if the BIOS detects your hard drive. If it is detected then make sure it is set as the 1st boot priority item. If it is not detected, then open up your laptop to inspect the wiring of the hard drive. Make sure it is firmly seated into the motherboard connector (Don't forget to have the laptop/pc powered off before opening the machine).
Next, remove the hard drive from the laptop and connect it to a motherboard from a desktop to see if it spins and loads the operating system. If it does work, then the hard drive is ok and the motherboard on the laptop is damaged.
You can also use a functional hard drive to install on the pc/laptop to rule out a bad motherboard.
If all of these don't work, you will need to reinstall your operating system because malware has damaged your operating system.
Aug 28, 2011 | Computers & Internet
When i install the xp cd in my hcl b23 C2D laptop, the problem shown like this. setup did not find any hard disk installed in your computer\r\nhow to slove?
verify that the hard drive is seen in the system bios. If it is not, disconnect and reconnect the hard drive then try again...the drive must be recognized by the computer for windows to see it. If the hard drive is definitely seen by the system, check to see if the manufacturer of your system offers serial ATA drivers for the system. Load the driver on a floppy disk, boot to windows CD, press f6, load driver, continue with installation.
Apr 12, 2011 | Microsoft Windows XP Professional
New computer built, XP installed, no full HDD capacity??
Check your motherboard BIOS specs. I know that Windows XP can see a larger hard drive but some BIOS issues could limit the maximum partition.
(My XP box started with a small drive but I added a larger SATA drive later and formated it with the XP disc management software. One caveat: I was using SP3)
To expand your partition, try using a third party partitioning software option. These will often save you from having to reinstall the os (sometimes things go wrong but mostly they are good). I've had good luck with Paragon Partition Manager and Partition Magic (before it was purchased by Symantec).
I hope this helps.
(Paragon offers a 30-day free trial of their Partition Manager software; however I am not aware of the limitations of the software.)
Mar 29, 2010 | Microsoft Windows XP Professional SP2
Hard Drive Not Recognized
make sure all wire connections are completely pushed in. try going in to the BIOS and see if it reconized it
Mar 11, 2009 | ASUS P5RD1-VM Motherboard
HP Pavilion ze5500 - Laptop won't recognize hard drive.
Hi. Once I had this similar problem with a HP Pavilion dv9000. "No Operating System"; "Windows Recovery Console cannot continue because there's no HD present..press F3 to Exit". No progress with Safe Mode nor Command Prompt, etc.
Then I went to the Bios, change tab to "System Configuration" and change the "Sata Native Support" to disable, whitch says that by changing to disable the HD would work better if the Operating System are Win2000 and Win9x.
Hit "Safe and Exit" and the computer started normaly!
I relly don't know how or why. It just work.
I don't know if would work for Linux (mine had Windows XP) and don't know the Bios view of your laptop. But you can explore and give it a try.
Hope this helps.
God Bless You!
Jan 06, 2009 | Computers & Internet
Won't boot from 500GB SATA drive
Windows XP original support up to 137GB
Windows XP sp1 support up to 250GB
Windows XP ps2,3 have not change.
you have to enable 48 LBA in order for the system to recognized the drive.
the exact porcedure is list in the link ;
http://support.microsoft.com/default.aspx?scid=kb;en-us;303013
Nov 17, 2008 | EliteGroup PM800M2 Motherboard
Reboot with new hd
Try Checking if your motherboards bios will recognize the hard drive. If not, Then the hard drive is probably damaged.
To access The bios, Most Motherboards open the bios when you press the delete key
If you have two or more hard drives then the settings of the jumpers eg. Slave,Master,Cable Select.
Because they might be conflicting with each other.
I had the same problem, But I tried installing XP Home edition on my secondary hard drive and it works.
But i need to insert my xp home install disc to get it the bios to recognize that windows is installed otherwise it goes " insert system disk and press enter"
Oct 11, 2008 | E-Machines (308714) Motherboard
IBM ThinkPad T43 Notebook Logo
93 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
