Question about Suspension & Steering for Audi Q7
Q7 has been jacked up without being put in jacking mode and now suspension won't reset properly, how do i reset?
3 Suggested Answers
wolfepac
  • 27 Answers
SOURCE: How do i diactivate jack mode in an Audi Allroad
Hold upper and lower arrows at same time for about 10 seconds to activate and deactivate jack mode. OR start driving car and it will automatically deactivate I believe when speeds are sensed above 5 mph.
Posted on Jun 29, 2010
wolfepac
  • 27 Answers
Posted on Jun 30, 2010
Rear air suspension is VERY stiff since changing right rear tire
Couple questions.
why was the tire in need of being replaced?
was there any damage or impact to the car?
when was the last time it was jacked up or lifted?
the first things that come to mind is a bent or hyper extended shock.
second thing that comes to mind is maybe somebody jacked it up one a suspension part and bent it
Jan 02, 2016 | 2002 Buick LeSabre
My computer won't turn on and when I plug it in the charging light won't come on
Please check the adpter output voltage with multimeter in DC mode.
If output voltage is good then check any contact problem of the power jack with laptop dc jack for proper contact.
Try to power on with only ac power supply by removing the battery.
Jun 14, 2011 | Computers & Internet
I have the car to low error message on the display the bags are bottomed out and wont raise up. its on a e 500 2003
The suspension has a leak somewhere and/or the airmatic compressor has stopped working properly. You need either the Mercedes star diagnosis system (SDS) in order to access the suspension control module to tell it to raise the vehilce or you can try to trick it by jacking up the car so it thinks it's sitting at the correct ride height. But as long as the display reads a warning it won''t allow the airmatic compressor to run.
Oct 12, 2010 | Mercedes-Benz 500-Class Cars & Trucks
Air suspension in the rear will not hold air in Mark vll lincion
there are 2 ways of fixing that problem you can replace whats broken which is more than likely the air bags, which is expensive, or you can get an aftermarket set up with regular springs and do away with the air bag system completely it's not hard to convert it over just unplug the compressor jack up the car to lift the weight off of the suspension put a jack under the rear end housing and loosen the the shocks and lower the rearend housing remove the air bags put springs in their place jack up the rear end bolt shocks back up and your done.
Jan 12, 2010 | 1995 Lincoln Mark VIII
Rear suspension has jack up and won't lower on
Possibly the height sensors or valve block at fault. Or a compressor failure. May need to be put on the diagnostics machine to check.
Jan 11, 2010 | 2003 Land Rover Discovery
What are the best jack points for my '94 Jeep grand cherokee?
Best place for jack is under the end of the axle tube, just before trailing arm attachment point. This will lift axle and tire without extending the suspension. This also depends upon what the ground is like where vehicle is parked. If ground under axle is soft, you can place the jack under the chassis to avoid having the jack fall over or sinking in. Or, if you can, move to more solid ground. What's more important is where not to put the jack...never place it where a suspension arm is attached, on a suspension arm that will change angle as it is going up, on a floorboard or anywhere it will crush a brake or fuel line. If you travel where ground is usually soft, carry a 1" thick 20x20 square of plywood (I carry same made from 1/2" steel. Use it under the jack to spread the load). Though "factory" jack will do the job, I suggest you invest in a halfway decent floor jack with a locking pin (a bit more reliable and safer)
Jul 18, 2009 | 1994 Jeep Grand Cherokee
Hi my front offside suspention spring has cracked an i need too know how to remove it thanx . its for a renault 19 16v 1995 model
I have a renault 19 with the same problem on the passenger side front. It is a straight forward job, you will need two jacks, preferably trolley jacks. It would be alot easier (and cheaper) to completely replace the suspension strut itself rather than squeezing a new spring in. Jack up the car then jack the suspension to a point it will hold suspension in place whilst you undo the bolts etc. Once bolts are undone, SLOWLY release the jack on the actual suspension strut and remove the strut. To replace the strut, put new strut in place jack it up into place carefully so you get it to stay in place. Do up all your bolts, Slowly release jack on suspension strut, then release the other jack holding up the car. I would do this with my car, but i cant be bothered as it has numerous other problems and im scrapping it.
Mar 11, 2009 | 1986 Renault Sport
3500 watt pure sin wave inverter
This engineer, Mandfred has a "Nightmare Story" for you ...
http://ludens.cl/Electron/chinverter/chinverter.html
If you have the exact same model, Power Jack 3500, then I seriously doubt you will ever get your inverter working long term without making all/most of the modifications that he made.
Oct 26, 2008 | Statpower PW-1750 Triple Outlet 1750 Watt...
Suspension & Steering for Audi Q7 Logo
561 people viewed this question
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ray gallant
Tom
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
