Question about Toshiba SD-3990 DVD Player
Disc won't spin - Toshiba SD-3990 DVD Player
  • Toshiba Master
  • 508 Answers
Check the spindle motor (this is under the disc table - which the centre of the disc sits on). If it measures open-circuit, it is faulty and not economical to replace, or (in rare cases) the voltage rail to it is short-circuit (it is more likely to be the motor itself which has failed).
If it is simply siezed, carefully lubricate its bearing (the base of its shaft just under the disc table) with some RP-7 or WD-40 spray (available in most auto shops) or CRC electronic switch lubricant (this is also a spray like WD-40 but also cleans contacts as well as lubricates), while gently rotating (edge of) the disc table in both directions. Don't get dirt and grease on the top of this - or it will transfer to discs.
Don't use too much of the above spray cleaners. A little bit is all that is required. It may or may not fix your problem. ONLY do this if your player is not under warranty; otherwise submit it to an authorised service centre and get them to quote for any replacement parts and labour involved, then decide if it worth repairing or cheaper to buy another player - up to you.
You should only consider replacing the whole unit as a last resort when you have exhausted all other possible options.
Posted on Mar 21, 2011
Discs won t spin
If your discs wont spin, I would contact sony if your PS3 is still under warranty. If not than buy a new PS3 or start buying your games digitally to play them with no disc.
Mar 09, 2014 | Sony Playstation 3 (PS3) Console
Won't read any kind of disc it spins and stopped like 3 times and doesn't move anymore
Sounds like you later lens has been damaged or is dirty. There is a cleaning kit at Walmart. If that doesn't work, google a local repair shop.
Feb 16, 2013 | Video Game Consoles & Games
Disc won't spin or register on my koss pc36
Check and replace its sled motor
Nov 26, 2012 | Televison & Video
My blu ray player won't play the hunger games
Need more info. Does the player accept the disc? If so, do you hear the disc spinning inside? If not, what does the player do? Does it kick the disc back out? Will this player accept and play other discs?
Sep 10, 2012 | Sharp Aquos Bd-hp22u 1080p Blu-ray Disc...
Does not spin dvd
Sometimes the brushless motor driver circuit fails. Rarely does the motor itself go bad. On some models, if the the laser diode is too weak to read the disc, the player will not bother to spin it. It won't spin so a lens cleaner disc won't work You can try to take it apart and clean the tiny lens. Don't use alcohol. Windex and a Q-tip works great to remove grease and dirt. Don't buff it hard. Just wipe lightly a few times and look at it at an angle to make sure it is shiny, not hazy. Almost all of these are not an economically viable repair. If cleaning the lens does not help, you are looking at another portable player.
Sep 02, 2012 | kawasaki PVS-10921 Portable DVD Player
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
Cd player won't spin disc
HelloCheck the sled motor. it is the motor that spins the disc inside, as soon as it has been loaded. Check the voltage comes to the leads of the motor first. If the voltage is there, and the motor does not spins, repalce the motor. It is a stepper motor, can be bought from most of the electronic spare part shops at your town. it is not a very colstly component. OK.
Dec 19, 2011 | Sony Audio Players & Recorders
Power works; fan spins;light is on; promo screen works; disc won't read; disk won't spin
The most likely situation you have here is that the cd drive lens isn't reading, just because with a gamecube, it relies on that lens to detect if there is a disc inserted. Your best bet is to try and clean the lens with a que tip and some rubbing alcohol. Be gentle, only very gentle wipes back and forth in a circular motion, then dry it the same way. If that doesn't work, I can give you some tips on how to rip the thing apart and see if it is a connection inside somewhere
Sep 09, 2011 | Nintendo GameCube Console
My playstation 1 won't play any games. It will start up with the disc spinning but then the disc stops spinning and i end up on the memory card screen.
DEAR FRIEND CHECK YOUR PS LANCE EYE AND CLEAN I HOPE READ PLY STATION LOGO THAN NOT PLAY , CHECK YOUR PCB BORD RBI CHANGE THAN REMOVE YOUR PROBLEM I HOPE SOLVE YOUR PROBLEM TACK CARE
Aug 21, 2011 | Video Game Consoles & Games
Toshiba SD-3990 DVD Player Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
