I have Modus ONE SIX Wharfedale speakers which keep blowing tweeters I have installed circut breakers rated at 1.0 Amp into them and still blow them up. My amp is a Adcom GFA555 200watt and the speaks are rated at 150 watt. I dont believe distortion is an issue. My pre amp is a pioneer elite vsx91thx both mid end equipment nto the Wharf's. How can I protect the tweets?
  • 5,370 Answers
Overdriving the tweeter or using an improper crossover are usually how tweeters get blown. It is always BETTER / SAFE to get speakers (tweeters) that are rated higher than the amps.Try connecting a standard automotive bulb in series between the crossover output and the tweeter. This bulb will light up a little bit and absorb excessive power going to the tweeter.but when the bulb lights up, at that time there will be bit low sound/volume noticed. ------------- Also if its blowing when volume is too high or on bass mode when volume is high, then turn the volume down when you turn it on.If the volume is on high and you turn on the unit.Then it gives direct **** to the tweeters and it blows the tweeters.-------------- You don't have to power off the amp, you can just turn the volume control all the way down. The spike generated by that pop will break the wire connecting the voice coil to the terminal. ------------ check out.Keep updated.Thanks.helpmech.
Posted on Mar 20, 2011
Wharfedale Modus one six - one woofer cone is cracked. It still plays, but needs to be replaced. Where can I buy a replacement, or is it possible to repair the cone?
Yes, you can bring it to electronic repair shop to rewind the coil. or buy it in the electronic shop. if they don't have same brand you can replaced it with other brand same size and same watts of speakers. thanks
Apr 30, 2011 | Wharfedale Modus One-Six Speaker
Is the tweeter a stand alone 8 ohm speaker?
yes, but it is attached to circuitry that allows only the high frequecies into it. You can replace the speaker with any 8 ohm tweeter without any difficulty, but if there is a capacitor across or in series with the speaker, make sure you put it on you new speaker the same way.
Mar 20, 2011 | Wharfedale Modus One-Six Speaker
Ok..... I have some Wharfedale Modus 8s. My question is, is that the base speaker is crackling a bit. typically when you don't have enough power the tweeters will clip first and go out. perhaps i did...
Dunno how old they are, but I just had an 11-year old pair of woofers re-edged because the foam surround and the adhesive had deteriorated. Upon close inspection the foam surround was noticeably pulled away from the cone in a few spots. Unfortunately, if there is an age-related issue with materials beneath the surface that you can't see, you'd have to pull the driver to check it out.
It wasn't until I turned my bass up loud that anything sounded wrong, which precipitated looking for the culprit (quickly found).
Nov 08, 2010 | Wharfedale Modus One-Six Speaker
I need to buy one Wharfdale Modus 8 speaker only.
Hi.
I have this modus 8 in good condition want to sell it if you wish.,
my email: devizal@cbn.net.id.
locatd at jakarta,indonesia
my mobile nos. (62) 816-809066
cheers
Apr 18, 2009 | Wharfedale Modus One-Six Speaker
Modus one six speaker not working properly
Hi. If you have an digital multimeter to hand you could always drop the drive unit (the metalwork with the paper cone) out from the enclosure and make sure the resistance of the voice coil is between 4-16 ohms. If there is no reading then the voice coil could be open circuit and the whole drive unit will need to be replaced. If the others rattle check the mounting screws are not slackened off. Especially if you have been driving them hard!
Dec 23, 2008 | Wharfedale Modus One-Six Speaker
Modus One Six spare parts
You may want to check ebay, they sometimes have drivers for sale. Additionally, I would contact IAG (International Audio Group). They are the distributor for Wharfedale here in the states and may be able to help you. I also have the modus one-sixes, modus-two's, and modus center and was albe to get replacement parts from IAG, never needed a driver though. How did you blow it anyhow, these speakers can take a beating, are you using a quality amp? Underpowering the speakers and trying to drive them loudly = demise for your speakers.
May 03, 2008 | Wharfedale Modus One-Six Speaker
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
Jan 15, 2008 | Wharfedale Modus One-Six Speaker
Tweeters only works when touched!
This is not a solution, but I have the same problem. Obviously, the problem is with the tweeter not the crossover. I can't find a replacement tweeter so i am about to take it to my local stereo repair store and see if they can fix it. If you find a replacement tweeter, let me know.
Oct 13, 2007 | Audio Players & Recorders
74 people viewed this question
 Grubhead
Grubhead
