Question about Delta JT360 6" 120/240V Deluxe Jointer
I have a Delta Jointer model # JT360. I'm having an issue with the out feed table, the very end of it is to low. How do I adjust it?
  • 710 Answers
There is an adjustment knob under the outfeed table.
The adjustment it gives is quite small.
Good luck
Handy Andie
Posted on Mar 20, 2011
In feed table is not level from front of table to fence
Fill feed table with water and measure water level at all corners and adjust until all corners have the same water depth. Then then drain and fill with feed. The fence should be near the feed table.
Aug 12, 2013 | Delta X5 Dj20 8" Precision Jointer
My outfeed table does not run level with infeed table . How do i adjust?
The most important part of the jointer is that the cutting edge is perfectly level with the out feed table, then, bring up the infeed table, with straight edge on rear, make all adj necessary to get these things lined up flat, not level, but flat, straight, even. Then it will cut perfectly flat and even. no snipes,. Hope this helps.
Feb 05, 2012 | Delta Masonry Tools
I cannot level the tables on my jointer. When I place a level on my tables,the front of the in table is about 1/4" low. how do adjust it? Or better yet where can I geta manual?
Please go to this link, download the instruction manual, then read and understand it before using your jointer. Incorrectly adjusted, even correctly adjusted, jointers can be dangerous tools, and failure to heed the instructions can easily cost you the loss of a fingertip or worse. Only when properly adjusted with the jointer be of any worthwhile use, anyway.
For more detailed information and numerous good articles with details on how to tune and use a jointer, search google for "jointer tune up".
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 06, 2011 | Delta JT160 Shopmaster 10 Amp 6 Inch...
I have a Delta DJ-20 X-Series 8" jointer. I cannot get the infeed and outfeed tables level wth each other. It appears that the outside ends of both tables are to low. Any suggestions?
If you are still interested, write back, but in general you will find a wealth of information online if you search "jointer tune-up" Fine woodworking has had several excellent articles over the years detailing the steps required to adjust the gibs or parallelogram table ways to compensate for this type of sag.
It is time-consuming but worth the effort if you wish to joint straight edges. Maybe check your local library for back issues on microfiche or some such. Sometimes you can get a bit of the sag out by merely cranking on the tightening knob a bit, but that works better on a machine with dovetailed ways and gibs.
Apr 30, 2011 | Masonry Tools
I HAVE PURCHASE A USED DELTA DELTA 360 TABLE JOINTER. I DID NOT RECIEVE A MANUAL.CAN YOU ASIST...MIKE
You can find this in the Downloads section of this page:
http://servicenet.deltaportercable.com/Products/Detail/JT360
Mar 01, 2011 | Computers & Internet
The knives on my Delta jointer don't contact the trailing edge of the board. As a result the board has a convex edge (high in the middle) The tables are parallel and the outfeed table is flush with the...
The knives could be dull, you would have to be the judge of that. If the bevel & face are rusty they are probably dull. They can be honed or taken to a sharpening shop.
The outfeed table could also be too high. I usually adjust the knives above the outfeed table. I use an aluminum straight edge & adjust them using a sheet of printer paper on the outfeed table so that they are about the thickness of the paper above the table. I place the paper on the outfeed table put the straightedge on the paper & rotate & adjust each knife so they just slightly hit the straightedge when I rotate the cutterhead by hand. Needless to say the jointer needs to be unplugged while doing this.
The board could also be convex to start with. To fix that problerm start jointing at the start of the convex part and not at the end of the board.
Good luck,
Frank
Jun 17, 2010 | Delta Machinery Delta 37-658 Jointer...
Need manual for Jointer
Go to this link and you'll find a complete parts diagram, list, and pdf manuals for your jointer.
Dewalt service net
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 04, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Infeed Table leveling
Well, the infeed table is supposed to be lower than the outfeed table. This is how the jointer actually removes material to flatten a face or board edge. What is important is that the the outfeed table is level with the top of the cutterhead blades, so as you push material through the cutterhead, the outfeed table fully supports the workpiece.
The infeed table is supposed to be adjustable up and down to remove different amounts of material.
If both infeed and outfeed tables were aligned, no material would be cut (assuming the outfeed was aligned with top of the blades).
Feb 28, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Delta JT360 6" 120/240V Deluxe Jointer Logo
204 people viewed this question
Top Delta Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Delta Measuring Tool and Sensor Expert? Answer questions, earn points and help others
