Question about Lexmark X4530 InkJet Printer
Printer will not completely feed through the printer
    Genius:
  • 1,087 Answers
There could be something that's blocking the paper path. This article in the Lexmark website on Paper Jam and Misfeed Troubleshooting in the Lexmark X3500, X4500, X4600 & X4800 Series All-In-One might help fix the problem.
Posted on Mar 24, 2011
Paper completely jammed
Lift feed panel, then the cover. carefully pull in thedirection of normal feed onto the scan plate. Do not try to pull out from the entrance.
Mar 13, 2015 | Canon Pixma MG3150 All-In-One Color...
How do I get my Eltron LP2042 into ELP mode?
After loading labels into the printer, place the power switch in the"0"(OFF) position.Press and
hold the FEED control while placing the power
switch in the"1"(ON) position.Release the
FEED control when the printer starts feeding
labels.The POWER indicator will turn off and
then switch toGreen while the adjustment is
being made.The printer will advance 3-4 labels
while performing the adjustment. When the ad-
justmen tis complete,a status summary label will
be printed and the printer will be placed in
Diagnostic Dumpmode.Tap the FEED Control
once to switch theprinter back tonormal opera-
tion. When the indicator switches to Green, the
printer is ready for use.
May 08, 2014 | Zebra Eltron LP 2824 Thermal Printer
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
I have a Canon Pixma iP1900, it will initially grab the paper but then the paper will just stop but the printer will continue while the paper doesn't move. Then when I cancel the printing it tells me that...
Hello -
From Support information I found on the Canon website, the paper feed rollers of your PIXMA iP1900 may need cleaning.
Source:
https://www.canon.co.uk/support/consumer_products/content/faq/?itemid=tcm:14-609974
The feed roller cleaning function allows you to ckean the paper feed roller. perform feed roller cleantng when there are paper particles sticking to the paper feed roller and paper is not fed properly.
The procedure for cleaning the feed rollers is as follows:
1.Prepare the printer
Remove all sheets of paper from the rear tray.
2.Open the printer driver setup window
3.Click Roller Cleaning on the Maintenance tab
The confirmation message appears.
4.Execute paper feed roller cleaning
Make sure that the printer is on and click OK.
Paper feed roller cleaning starts.
5.Complete paper feed roller cleaning
After the rollers have stopped, follow the instruction in the message, load three sheets of plain paper into the rear tray, and click OK.
Paper will be ejected and feed roller cleaning will be completed.
Best wishes.
Feb 07, 2018 | Canon PIXMA Office Equipment & Supplies
Paper Shooting Out
Please have a Check on the below mentioned Points and follow the steps:
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
Good Luck!!!!!!
Mar 28, 2013 | Lexmark X4650 All-In-One InkJet Printer
Document feeder will not feed
There are several things that can cause this.
1. stuck paper inside feed assembly 2. the feed assembly tray is NOT completely closed, please close it 3. The printer has an open compartment located somewhere on the exterior of the printer 4. The printer is not turned on
Thank you for allowing us to help, please respond with further questions and concerns Spanish speaking available for all problems Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
Jan 09, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
The paper isnt going through
If the paper feed rollers are not clean, they may slip and cause paper feeding problems.
The problem may be alleviated by performing paper feed roller cleaning.
1. Open the Printers folder.
- For Windows XP Home Edition Click/Select "Start," "Control Panel," "Printers and Other Hardware," and "Printers and Faxes."
- For Windows XP Professional Edition Click "Start" and "Printers and Faxes."
- For Windows 2000/Me/98 Click/Select "Start," and "Settings," then "Printers."
2. Right-click the icon of the printer for paper feed roller cleaning, and select Properties from the displayed list.
3. Click the Maintenance tab and click Roller Cleaning. 4. Remove all sheets of paper from the auto sheet feeder, and click OK. 5. Confirm the message to be displayed, and click OK.
Do not try other operations until printer's operation completes.
6. When the printer's operation is completed, follow the confirmation message to load three new sheets of A4 or letter-sized plain paper in the auto sheet feeder
7. Click OK.
8. Confirm the message to be displayed, and click OK.
Do not try other operations until all the three sheets are ejected.
Memo: The printer prints nothing on those sheets.
9. When all the three sheets of the paper are ejected, paper feed roller cleaning is completed.
10. Click OK.
Performing Roller Cleaning is completed.
Nov 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper feed problems
Try uninstalling the printer software and driver completely and install it again
Sep 08, 2009 | HP PSC 1610 All-In-One InkJet Printer
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Sep 06, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Lexmark X4530 InkJet Printer Logo
81 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
