Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Will not back up small in grades and will not pull lawn roller more than fifteen min.
    Brigadier General:
  • 3,911 Answers
Be looking around for a new hydrostatic transmission. get the manufacturer and part number off the bottom, stamped in the metal along one of the rear axles. there are just a few companies that make them. often times these are sold "new old stock" on eBay for a few hundred bucks but purchased new from a vendor will be over a grand.
Posted on Mar 21, 2011
1989 Ford 150 4cly truck will run fine then starts cuting off and dies out . . no one can fix it. in shop now. shop owner pay labor can not fix. in shop 50 days
Hi, Check fuel pump that it is running properly. Sounds like an electrical problem with the pump. Good luck.
Oct 29, 2012 | 1996 Dodge Ram
Kodak 3250 printer pulling multipule papers causing jam
Most likely, the rollers are worn out. Since this is a consumer grade printer, you will be unable to replace the rollers. You might pull the paper tray and try to clean the rollers with rubbing alcohol. Sometimes this will work, but most the time the wear is enough that nothing will stop the printer from feeding multiple sheets.
Feb 13, 2012 | Kodak ESP Office Equipment & Supplies
What job of the number around a clock
Hour, minutes and second hands tell the time in relation to the day time light through until dark. The small round clock perform a similar function only that the grade meters appear different describably. The small clocks measure time by assuming the time in four quadrants of fifteen minute intervals where each intervals on the quadrant is symbolic of North East South and West as in compass directions. Every fifteen minute of the small clock indicate being within a compass measure zone tchnical measure of time of day in relation of geographic direction. Unlke telling the time with the big clock without consideration of the situation of the timer teller. The small clock is designed to tell the time in reference to the direction of the time teller, a feature which would have required compus together with ordinary watch to ascertain what the small clock attempt to provide all in one watch.
Dec 03, 2010 | Rolex Daytona 116520 Wrist Watch
I have Craftsman 42" lawn tractor with the automatic transmission. It runs fine but it is not pulling a grade now. The belt seems tight, what could be the problem?
As you attempt the incline grab the clutch pedal with your heel and pull it towards you if it starts pulling correctly you have a belt problem . If it makes no difference you are having hydro pump problems
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My L130 lawn tractor will not pull a small trailer or pull itself up a small grade. The hydrostatic pumps seems to be bypassing or something. The lever is all the way in. Is there an ajustment to the pump...
Your hydraulic oil level may be low or your oil needs to be changed. All oil will slowly build up water contamination and cause it's viscosity to change (make it thicker). Manufactures usually don't tell you what kind of oil it is so you are usually stuck buying their oil. Which I highly recommend. The wrong oil will not break the pump but will cause it to work oddly.
Mar 29, 2009 | Garden
Printing fuzzy
Sorry for the delay in getting back to you.
There are several things that can cause these problems.
Low grade toner. Have you noticed that fuzziness is always the same color or not?
A weak "Charge Roller" not charging the PC as it should.
A problem with the spinning mirror inside the laser unit.
The "Transfer Roller" not charging the paper properly.
To high a charge on the paper could cause artifacts on the PC to be pulled to the paper.
The fuser roller not getting properly cleaned and depositing residual image back on the paper.
Paper slipping in eiter the Tranfer Station or the Fuser.
I would suggest you place a service call on the unit and let a factory trained tech diagnose the failure for you.
Don
Jan 14, 2009 | Lexmark C762 Laser Printer
How do I change the belt on a 2991AVZ bagless vacuum
release the handle on the vacuum until it rests flat, then look at the part of the machine that has the hieght adjustment knob on it, that is the hood of the vacuum. there are usually three screws that hold it on. There should be a screw on the left and the right of the knob (towards the sides) and then the third is near where the small hose sticks out of the hood. once those are out the hood lifts up you will need to pull up on the brush roller ( you might need to use a small flat head screwdriver to pry it out, place it between the end of the brush and the housing and pull ) then take the new belt and place it over the small metal shaft that sticks out from the motor then put the belt on the roller and pull it into place dropping the roller back to where it was. also try turning the roller by hand to make sure you didnt pinch the belt under the roller.
Sep 17, 2008 | Eureka Vacuums
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
132 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
