Question about Health & Beauty
Can not get the scale to register in pounds anymore. it only registers in kg. i have flipped the switch to lb on the bottom of the scale
    Sergeant:
  • 236 Answers
The slide switch contacts are probably dirty or oxidized. The easiest way to clean the switch contacts is to just flip the switch back and forth several times. Best not to spray anything into the switch as it will likely attract dust and cause further problems in the long term.
Posted on Mar 20, 2011
How do I change scales 9113from kgs to pounds and stones
Hi Geraldine.
Is your question about a scale MODEL 9113, or do want to calculate Kg to lb & st?
If scale, please add more about it.
Google search for "9113" brings up gazillions of hits about everything on our planet. :)
Regards,
Clive.
Oct 28, 2017 | Health & Beauty
How do I change it from KG to pounds?
That basic conversion is 1 KG = 2.2 LB. so if you have 5 KG, the you have 11 LB.
There are a number of online calculators that will do more exact conversions for you.
Apr 25, 2015 | Health & Beauty
Conversion from kg to pounds or ounces
1 kg = 2.20462 lb
[http://www.metric-conversions.org/weight/kilograms-to-pounds.htm]
1 lb = 16 oz
Apr 15, 2015 | Home
ST KG LB
Stone; Kilograms; pounds. Howzat!
Sep 09, 2012 | Taylor & Digital Scale Lithium Scale
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
Jobar international JB5413 large cap. scale It shows in kg i want to change it to pounds.
press WT then press SET for 3 secs
then use up/down arrows to change between kg lb and st
when selected press SET again
Dec 07, 2010 | Jobar International Idea Works Wireless...
Changed batteries and now the scale does not read correct weights. off by more than 40 lbs
You might wanna double check that your scale is set to the right measurement. On the bottom of the scale is a switch that allows you to choose between Kg (kilograms) or LB (pounds).
Jan 18, 2010 | Conair WW60 Weightwatchers Scale
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
Conair ww17 scale measures in kg not lb.
There is a switch on the bottom of the scale on mine to use either lb. or kg.
Dec 11, 2008 | Conair Large Digital Display Memory...
Health & Beauty Logo
59 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
