I have a hp pavilion a226n and no signal to the monitor I have replaced the cords and the monitor works on my other computer what do I need to do
    Brigadier General:
  • 4,044 Answers
Replace the Video Card after first making sure the card is fully seated in the Slot. If you added a different card to the expansion slot just below the video card move it to another slot.
Posted on Mar 20, 2011
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
Hp pavilion 6648c no signal to monitor
Make sure the cable is in good on the back of the computer and on the monitor. If the cables are in good, then either the monitor is bad or the video card is bad. Try using another monitor on the computer. If the other monitor gets a No Signal then the Video Card is bad. If the other monitor shows a display and works, then the original monitor is bad.
May 01, 2012 | HP Pavilion 6648C PC Desktop
Hp pavilion 763 no video signal
Hook a spare monitor to the pc, if picture okay! there is a problem with the HP monitor. But if both show the same symptom it is the Video Graphics Card that is defective in the computer, "a thought" change the video cord from the computer to the monitor to be sure.
Apr 07, 2012 | HP Computers & Internet
How do I fix my hp w17e monitor that reads "VGA no signal"? I've tried unplugging my power cord and holding the on button for 30 seconds to a minute and plugging the power cord back in it still...
VGA no signal means "no signal" from the computer on the VGA (blue plug) cable... ...if the computer works check the cord for loose connection or get a new cord...if the computer is hooked to the digital cable (DVI/white plug)...set the signal source on the monitor to digital...
Feb 14, 2011 | HP w17e Monitor
My fathr gave me a hp f1703 monitor. As soon as i plug it in the whole screen flashes on and off. The light on the power cord also flashes, but if i unplug the monitor and leave the speakers plugged in the...
try another monitor i re placed my cord and the graphics card and it didn't do me any good i replaced the monitor last and it works fine now. and my speakers pluged into the monitor the monitor i bought didn't have the port for speakers so now i need to get usb speakers so check it out. hope this helps
Oct 17, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Jun 16, 2009 | HP Pavilion a450n PC Desktop
Hp pavilion monitor not starting up
That will happen if the monitor isn't getting a video signal from the computer. Are you sure your computer is actually starting up properly? Are you hearing the normal Windows startup sounds? If the computer and Windows seem to be working properly, the video card or integrated video may have failed. Have you tried another monitor to verify that the computer is working?
If the monitor is in fact bad, it would be better to replace it than to try a repair. New LCD monitors are quite inexpensive and you'll gain lots of desk space.
Mar 13, 2009 | HP Pavilion MX70 17" CRT Monitor
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Supplying power to the monitor to get it to work
I think what you need is a "D" shell connector.. see if the one that fits your PC Power Supply will fit into the Monitor.. if so then purchase another the same. It's called a "D Shell" Power Cord.
Aug 20, 2007 | HP Pavilion F50 17" Flat Panel LCD Monitor
Computers & Internet Logo
David Payne
David Payne
