Question about Sony Audio Players & Recorders
I have a Sony STR-AV770 receiver that has stopped its output of volume to the left side. Any chance of me fixing this on my own?
  • 604 Answers
Your question depends on how good you are at electronic diagnosis (symptom diagnosis) and how adept you are at removing and installing electronc components. first you have to determine why the amplifier has stopped working on the left channel. Make sure that the problem isn't a simple one, take the speakers off the right side and hook them to the left side and see if you get sound. If you do,, then the problem is the left speaker or left speaker wire. If you don't get sound then tyr taking the input that feeds the right channel and pluggin it into the left channel and listen for sound, if you get sound now the problem was the signal from your source not being sent down the left side.
If it still doesn't work you need to move inside the amplfier, but first, get close to the back of the amp and give a sniff, do you smell anything (a pungent burnt wire or rubber smell) if you do, the the chances are good that some components have burned out. Do you recall having a shorted speaker wire on the left side? shorted speaker wires are notorious (especailly older equipment) for burning out the final amplifer stage. If this was an expensive amp it might be worth fixing, if its not worth much then maybe you should consider religating it to use as a monophonic amplifier (one channel) you could use it to power a sub woofer in a hibryd stereo or surround sound system.
I don't know what more I can tell you at this point. If you go through the steps I outlined, and want to tell me the result I shall be glad to respond and maybe give you another direction to head in. good luck and I'm glad you are adventruous enough to want to try.
Posted on Mar 20, 2011
Can I get digital output through my STR-DE945,
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE945-Receivers-manual/id/387dj982/t/2/
The far left optical connector on the back is an output.
Feb 21, 2011 | Sony STR-DE945 Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Have a str-de 945,unit was working,sound stopped,still powers up.Replaced 2, 8 a fuses,blew again,nothing was connected to the unit.The heavy power supply unit in the front seems to have a hard orange...
Chances are you have shorted output transistors,check with ohm meter across all 3 legs,there should be no shorts if good.. cost on average around 150.00
Apr 16, 2010 | Sony STR-DE945 Receiver
HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Mar 21, 2010 | Sony STR-DE675 Receiver
The protector flashes STR DE625
Chances are it will need replacement parts (output transistors and a couple of resistors) Probably best left up to a repair shop tech.
Feb 01, 2010 | Sony STR-DE625
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
Output
When you change the selector switch, do you hear the relays inside the unit? Is your muting button activated (found to the lower left of your volume knob)? Do you have speakers connected to A or B or both?
Dec 23, 2008 | Sony STR-DE685 Receiver
I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Aug 20, 2008 | Sony STR-DE975 Receiver
Sony STR-AV770 AM/FM Tuning
If your going to buy an antenna you could do some research at cccrane.com. They might be able to help you with the other problem too.
May 15, 2008 | Audio Players & Recorders
599 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
